p1235
I'm using the GST 93 octane w/boostpill basemap.
Right when the SES light comes on, it shifts strangely-almost like sport mode, and it idles higher. If I turn the car off and restart it, the light will still stay on, but the idle and shifting returns to normal. Turning it off/on a few more times will clear the code, or I can clear it with cable/ecu flash.
The only mods I have are: an HKS drop-in filter, Forge diverter valve, boostpill, Stainless UICP, and an Evo X intercooler.
Yesterday, I went out and tested to see if the light would come on after changing the bypass valve back to OEM. It still lit after WOT. Then I replaced the drop-in filter back to OEM and tried again. And again, the SES would light after WOT.
I'll try to answer any other questions you may have.
Do you have a way to log the car for me?
Just FYI, I should have some updates across the board on the basemaps soon...
- Bryan
You guys might want to try GST's COLD WEATHER 93 octane w/ boost pill basemap. That's what I did before getting the custom dynotune done on my car, and it seemed to clear up the problems I was having with the regular GST 93 octane w/boost pill basemap.
Meth Addict
Aug 19, 2009 06:05 PM
hameedosh
Jul 22, 2009 03:41 AM
hurstnova350
14
Dec 19, 2008 12:38 PM
