Most Powerful Ralliart?
Old May 23, 2010 | 08:58 PM
  #31
ambystom01's Avatar
And what's the torque? I'm curious as to how it can run that much power without any clutch slippage, warning lights, etc. given AMS' issues.
Old May 24, 2010 | 02:38 AM
  #32
Myszkewicz's Avatar
Pretty sure TTPR's 508hp RA still takes the cake.
Originally Posted by TURBO TECH P.R.
HELLO MY FRIENDS, I DID TOOK THE RALLIART LAST MONDAY TO THE DYNO WITH THE NEW TURBO A GARRETT/TIAL SPORT GT-35R FULL BALL BEARING .THE RESULTS 508 WHEEL HP AT 30 PSI AND 426 POUND OF TORQUE.
Unfortunately, he passed away some time ago.
Old May 24, 2010 | 09:36 AM
  #33
Cosis's Avatar
thats would have been on an older RA correct?
Old May 24, 2010 | 10:40 AM
  #34
GST Motorsports's Avatar
That isn't a 09+ 4B11 AWD Ralliart.
Great power though from a old lancer
- Bryan
Old May 24, 2010 | 11:55 AM
  #35
Cosis's Avatar
that much hp on fwd would be unreallll lolll
Old May 24, 2010 | 12:40 PM
  #36
ambystom01's Avatar
That much power with any drivetrain would be a handful. A friend has a 500 WHP STI and it's retarded.
Old May 24, 2010 | 12:45 PM
  #37
Cosis's Avatar
yeah it sure would be. I have 2 friends with 450 whp+ srt-4s are they just end up being gong shows.
Old Sep 24, 2010 | 10:09 PM
  #38
jsurfdog's Avatar
Sorry I didn't get back sooner. Not sure of how much torque, I don't have the dyno chart. David did it, and does have the chart if you want to look. The check engine light never came on again.
Old Apr 23, 2011 | 06:31 PM
  #39
ralli time's Avatar
i also hit over 320 torque and had some issues with the tranny but someone told me on another thread that it was due to our tranny's torque management? and that its not tranny slippage. they also mentioned somehow you can tune around it? does anyone know about this or if its true?
Old Apr 23, 2011 | 06:56 PM
  #40
Jdunn502's Avatar
Originally Posted by jsurfdog
My perliminary tune is done. Ultimate Racing turbo back exhaust with high flow steel cat, K&N filter panel, Evo X FMIC, UR upper an lower IC pipes, EVO X BOV. Vehicle is making 255 WHP on hub Dyno. 22PSI boost down to about 16 PSI at new redline, 7100 rpm. Will post dyno charts later. The car runs like a bat out of Hell, and sounds like it too. Noise level is painfully high in the cabin, drone from about 3000 to 5000 RPM unbearable under even moderate accelleration. My son and I spent most of the weekend ripping the interior out and installing $700 worth of Dynamat, Dynaliner, and Dynapad. This took the edge off the higher frequency noise, but did little to dampen the drone. We took a 40 mile trip on roads today, arrived with headaches.
Bottom line, the UR system from cat-back to pipe tips is coming out ASAP, the stock cat-back going back in. I'll keep the down pipe and high flow cat in initially, to see if the change in mufflers works. By the way, the UR system had the standard twin silencer set up, PLUS an additional silencer AND a resonator installed in the mid-pipe.
My wife told me she could hear the car coming from a kilometer away, and I was ******* it trying not to wake up the neighborhood on a Sunday morning.
Regarding the difference between the EVO X and Ralliart SST torque capacity, my Ralliart SST threw a check engine light when pushed while engine and FMIC cool. The message was torque level too high. This error message was deactivated by tuner in ECM. I believe the Ralliart and MR SSTs are the same, but the software on the EVO allows for a higher torque level before throwing a check engine light.
Dynamat is heavy...not good for drag. I also have a similar setup as you. but with a English racing tune. I can understand how you get irritated by the UR exhaust...it is very loud..but I love it and wouldnt trade it for any exhaust. My vehicle made 299whp and 260tq clutch holding just fine. Time for me to step it up and push the limits!!!
GST Motorsports
32
Dec 24, 2017 10:16 PM
iDriveWanaBeEvo
Nov 29, 2016 09:35 AM
LA_RalliArt818
21
Oct 8, 2013 08:29 AM
Masteroftuning
Mar 11, 2013 06:40 AM
GST Motorsports
May 20, 2012 06:34 PM
