About my Injen UICP..
Old Feb 21, 2011 | 09:48 AM
gloom's Avatar
I have only had it installed for about four days and today when I installed my new air filter I noticed the mid rubber clamping connecting the two pipes had something that looked like aluminium flakes on it? I touched it with my fingers and noticed it even brushed the injen text away.
What is this and should I be worried? Don't want flakes in my piping ..
Old Feb 21, 2011 | 01:44 PM
elmerfud54's Avatar
its probably vibrating against somthing. mine used to vibrate against my bov after i installed my intake. id also recommend putting t-clamps and a bigger rubber sleeve at that mid point. went on a long trip this weekend and it kept blowing off
Old Feb 22, 2011 | 04:04 AM
gloom's Avatar
Here is a pic of it. I have contacted Injen to see what they got to say. Maybe something is rubbing or is ill connected. None of the other connectors have flaked just this one which is weird.
Uploaded with ImageShack.us
Old Feb 22, 2011 | 04:15 AM
elmerfud54's Avatar
mine was like that on the under side of it. i wouldnt know what cuold rub on the top side
Old Feb 22, 2011 | 04:19 AM
gloom's Avatar
Interesting.. I will need to check if it touches the bonnet or something else weird
Old Feb 22, 2011 | 05:01 AM
Slee256's Avatar
I have an Injen UICP as well, and mine doesn't do that.
Old Feb 22, 2011 | 05:15 AM
elmerfud54's Avatar
mine vibrated against a couple different things after i did the x swap. forgot to mention that. had to rearrange everything. beforehand i had no rubbing issues
Old Feb 22, 2011 | 06:32 AM
wazzelby's Avatar
That definitely looks like something is rubbing on it. There's a wear pattern right up the middle at the highest point. Double check anything near it or even the hood for clearance.
91TSiGuy
Mar 31, 2015 02:26 PM
russ72
Jul 2, 2014 10:49 AM
RoryBarron
May 3, 2013 11:50 PM
kaonashi
Feb 5, 2008 01:58 PM
