Problem with logging data with Evoscan
Old Mar 1, 2011 | 03:23 PM
csra09's Avatar
So I hooked up the tactrix cable openport 2.0 and opened evoscan 2.7.. It has openport 2.0 selected and 2006+ can/evox selected along with mode 23 usa ra evox selected... I click the start datalogging and the car starts to idle crazy and the ses light flickers. In the corner in evoscan where it shows the event etc and turns green when connected. It turns green and then yellow then back to green etc.I know the cable works I've used it to flash the car via ecuflah. I did already try uninstalling the drivers on the tactrix still same problem. Also emailed evoscan support and was told they never heard of this. Any idea?
Old Mar 1, 2011 | 05:30 PM
sstevojr's Avatar
Wow, thats really weird. look at all the connector prongs, make sure when of them isn't bent or broken? I've heard how on scoobies if the asc (i think 8) slot is connected it can cause problems, but nothing for mitsu's...
Old Mar 1, 2011 | 07:23 PM
csra09's Avatar
The prongs are fine and connections are good. Thanks for the idea. Wish it would have been that simple. Anybody else using tactrix 2.0 and evoscan run into this or had issue with connecting? Should be pretty straight foward...connect... log data.....
Old Mar 2, 2011 | 07:09 AM
Mad_SB's Avatar
Are you sure mode 23 is enabled in your rom???
You may want to update evoscan to 2.8 and also make sure you have selected the proper vehicle from the dropdown list and that you have the proper data items defined:
https://www.evolutionm.net/forums/09...sses-info.html
I was able to log my 2010 just fine last night (First time trying) using the 55590007 deffs and evoscan 2.8. It should be noted that 2.8 (just downloaded and installed last week) did not have the correct offsets for mode 23 logging for the 2010 RA.
Old Mar 2, 2011 | 09:00 PM
csra09's Avatar
Yes the mode 23 is enabled and was reflashed afterwards... Im selecting mode 23 RA EVO X in the evoscan options. Just keeps doing the same thing. Mad SB, in the 09+ Ralliart evoscan adress/info thread, >Cataclysm< encountered the same problem but later said he could log... So what ever he did I need to do too. I sent him pm so hopefully works out. But thanks for the feedback.
Old Mar 3, 2011 | 05:32 PM
csra09's Avatar
Ok.. question.Im guessing since theses are unticked thats why I can't log. I need to enter the value amount 0x23,0x23, and 0x52 to actually enable mode 23. I was told the rom image already had it, but I thought you had to manually enter this correct? If someone could verify this looks correct much appeciated...
Old Mar 3, 2011 | 05:40 PM
sstevojr's Avatar
Open all three mode23 boxes and see what they say, s/b the second value in order to work (i.e. 0x23, etc)
Old Mar 3, 2011 | 05:49 PM
csra09's Avatar
They already say 23,23,and 0052. Does everything look to be in order? It does need to be entered manually in order to use the mode 23? I assuming this is the actually prolem.. forgive my lack of tuning and computer skills...Not my specialty. Thanks
Old Mar 4, 2011 | 10:55 PM
csra09's Avatar
So long story short ''not my speciality'' I overlooked some things but officially logging data as of now. So something not so complicated turned over kill from stress and not so much experience. Still learning and thats a other reason to log data. Very awesome to see some much info that never know until you "talk to the car" Very funny way to put it.
Old Mar 5, 2011 | 03:49 AM
Mad_SB's Avatar
Good deal,
Glad you got it sorted out If you don't mind sharing what did the trick and got you logging.... it may prove helpful for someone else stuck in this situation in the future
evoscan
52
Jun 20, 2017 01:46 AM
alexc
For Sale - Miscellaneous Automotive
Mar 12, 2017 08:54 PM
Evodetailer123
Oct 3, 2016 07:37 AM
evo4mad
May 5, 2015 06:22 PM
Danieln
Sep 5, 2010 05:08 PM
