Do I need a fuel pump w/E85
Old Mar 24, 2011 | 02:26 PM
EvoOtto's Avatar
Question Do I need a fuel pump w/E85
I looking into making the switch and wanted to find out if I can get away with just 1000cc injectors or will I need a pump as well. I plan on using the stock turbo. I'll add a test pipe and mod the stock muffler and call it a day. Any idea what Hp I could expect? Any input would be appreciated.
Old Mar 24, 2011 | 02:29 PM
evil03's Avatar
from what i have seen and asked you will need a new fuel pump and 1000cc injectors and maybe a tune??? is that correct?? because i am looking in to doing e85 as well
Old Mar 24, 2011 | 02:31 PM
EvoOtto's Avatar
I understand the tune is ness. Just want to get all my ducks in a row before I make the jump.
Old Mar 24, 2011 | 03:21 PM
vplukas101's Avatar
test pipe with the muffler mod and resinator del sounds good i like it
Old Mar 24, 2011 | 03:53 PM
QUANLOCO's Avatar
Yes defiantly a fuel pump.
Old Mar 24, 2011 | 04:16 PM
EvoOtto's Avatar
I wish I knew what it sounded like. Do you know if it has a drone?
Old Mar 24, 2011 | 04:50 PM
vplukas101's Avatar
i dont notice any drone, from the inside with the music off you can notice the exhaust slightly from the outside its quit but doesn't sound stock and has a back fire if you give it gas same thing when your boosting let off the gas and get back on it it has a nice quit backfire
Old Mar 25, 2011 | 04:20 AM
03chi-town0Z's Avatar
Pump will be needed, probably before injectors actually, but with a 255lph and 1000cc you'll have plenty for stock turbo. IIRC, that's the setup Bryan is using for the BBXLite on E85 so running on the stock turbo would definitely not exceed max IDC or pump output.
Old Apr 10, 2011 | 09:41 AM
Jim in Tucson's Avatar
EvoOtto,
Did you ever make the jump to E85? If so, update this thread PLEASE!
If not, git-r-done!!!
Old Apr 11, 2011 | 11:39 AM
EvoOtto's Avatar
LOL. I just ordered the 1000cc injectors. Getting the fuel pump, test pipe, and I/C ordered this week. Can't wait to put the project together. I will do a dyno before and after as well. I will post up my results as soon as I can.
Old Apr 11, 2011 | 12:31 PM
RazorLab's Avatar
I think you might be ok with the stock fuel pump with the stock turbo.
However it might be a good "might as well" upgrade.
Old Apr 11, 2011 | 02:27 PM
EvoOtto's Avatar
I was going to get a Perrin I/C. I can get the piece at cost but don't know if it's worth the extra money. I could pick up an Evo X used for about $200 less. Any thoughts?
Old Apr 12, 2011 | 07:35 AM
badreligi0n's Avatar
Alcohol fuels can be more corrosive on some rubbers , plastic and some metal parts, A fuel pump / injectors are needed for E85 because the stock fuel pump uses the oil in the gas to lubercate itself and E85 doesnt have the same lubercation properties. Same reason for injectors.
Old Apr 12, 2011 | 09:29 AM
RazorLab's Avatar
The stock fuel system can handle E85 just fine. It's the volume of fuel you need to address.
It's lubrication btw.
04_k20a2
Feb 21, 2012 07:20 PM
JugoSX
Jan 19, 2012 08:25 PM
Bizzlex
Jun 15, 2011 06:02 AM
evovin
Jan 22, 2008 02:27 PM
topnotch_EVO
Oct 17, 2006 02:20 PM
