Which Turbo
Old Apr 23, 2011 | 07:15 AM
RideSober's Avatar
Originally Posted by El-Diablo
Where can I get info about the CBRD RAD. I have checked the website and it isn't listed.
Current mods are.
K&N
Boost Pill
HKS cat Back system
FMICP
Creatd tune (Australia)
I currently make 180 kw at the wheels which is around 240 HP. Cars in this tune in Oz are running low 13's
The only information is what CBRD has posted on this forum. Use the search feature, also here is some information in this thread.
https://www.evolutionm.net/forums/09...s-testing.html
Old Apr 23, 2011 | 08:31 AM
Krisko's Avatar
You mail cbrd your turbo and I believe they will send you a temporary until that one is finished and mailed back, but it all cost to do. You don't have to have one mailed to you to save money but you'll be without a car for a short period of time. I believe that's how its done.
Also, cams should be able to awaken the power of the cbrd rad turbo too
Old Apr 23, 2011 | 01:20 PM
bobsmilie's Avatar
garett ftw
Old Apr 25, 2011 | 05:23 PM
NICK(PMR)'s Avatar
A car with the same power Rob ran a 13.12 a year ago with a Creatd Motorsports tune, which is still currently the fastest in OZ.
Old Apr 25, 2011 | 07:09 PM
newmitsuowner's Avatar
i started a thread a while ago. theres some good info in there.
https://www.evolutionm.net/forums/09...ming-soon.html
Old Apr 25, 2011 | 08:22 PM
RazorLab's Avatar
The fastest RA in Aus is a 13.12? The GST Basemap with boost pill but everything else stock has run 13.2 and low 13's on multiple occasions:
EvoOtto -- 93 oct BaseMap V2 + BoostPill = 13.2@101.99mph
Snipingdude -- 93 oct BaseMap V2 + BoostPill = 13.29@100.84mph
Silver09RA -- 91 oct BaseMap V1 + BoostPill + HKS filter = 13.36@100.91mph
omegis -- 2011 93 oct BaseMap V2.5 + BoostPill = 13.39 @ 101.9 mph
bobcrusader -- 93 oct BaseMap V1 + BoostPill = 13.5@100mph
Proteus_x15 -- 91 oct BaseMap V1 + BoostPill = 13.8@99mph
It would be interesting to see some of the Aus guys run the basemap on a other wise stock RA and see what they get.
As far as the OP's question.
I have the CBRD BBX Lite on my 2010 RA and I love it. Makes awesome power, spools almost like stock and I'm still on stock catback and the car is literally not any louder then stock.
More info here: https://www.evolutionm.net/forums/09...sportback.html
Old Apr 25, 2011 | 08:27 PM
RazorLab's Avatar
Originally Posted by Krisko
If you're going with something bigger than a OEM Evo X turbo, you're going to need camshafts. Without cams, your gains over the OEM Evo X will be REALLY disappointing, with cams, you'll make about 380whp with a fp green and 420whp with a fp red. However, don't look at gains between the green and red, look at your goals. The green has insane low end power and is more okay for a DD, while the red has not a whole lot of low end power but insane high end power and isn't recommended for a DD. So the green is perfect for 1/8 mile while the red is perfect for 1/4 mile, again, it's all about your goals.
Also, bare this in mind, IF you're going to track it with one of these turbo's, lots of other things are highly recommended other than cams. You're looking at a transcooler, 3 port solenoid boost controller, perhaps a bigger oil pan, oil cooler thermostat, small battery kit, sri/cai, wider tires, better brakes, the optional ssp gold trans fluid, and if you want to resist knock and run at much higher boost then you'll need 850cc-1000cc fuel injectors and an aftermarket fuel pump to run E85.
I'm trying to head your route, but no matter how cheap I find all of this new or used, you're looking at more than $5k
I disagree with this, there are a bunch of Evo 10's with the 4B11T that make excellent power with stock cams and larger turbos.
One example, I've tuned a 10 here in California on a stock turbo/stock cams, on E85 and it made 346 whp / 369 wtq on GST Mustang dyno.
Then he upgraded to a PT6262, went back to 91 oct, still stock cams and made 445 whp / 311 wtq.
Another example. 2008 Evo 10 MR. Tuned on stock turbo, stock cams, 91 oct - 305 whp / 300 wtq. Went to a CBRD BBX, still stock cams, still 91 oct and made 354 whp / 310 wtq
Old Apr 26, 2011 | 12:01 AM
NICK(PMR)'s Avatar
Hey Bryan,I was there when bobcrusader was racing his RA with you v2 tune with boost, standard exhuast it ran 13.59.
However it was a very humid day and the car that ran 13.1 had the mph to ran a 12.
Since then Creatd has tuned many more RA's which will be hitting the track very soon so will be intresting to see what the results will be.Bobcrusader had his car tuned by Creatd and is now making 189kw at the wheels. To give you a idea on how your v2 tune with boost pill result was it made 152kw atw which is fantastic for something you give out for free to public.
Old May 8, 2011 | 05:17 AM
parralegend's Avatar
I've got a stock 2011 RA from AUS and would be willing to try exactly what you said if someone could tell me if the 2011 map exists for aus?
Old May 8, 2011 | 10:32 AM
RazorLab's Avatar
If you can pull the ROM from your car and send it to me I can make a BaseMap for the 2011 EDM/AUS Ralliarts.
Old May 8, 2011 | 07:00 PM
NICK(PMR)'s Avatar
Have you seen the 2011 maps yet Bryan?
The 2011 Lancer Ralliart Aus spec has a lower fuel consumption then the previous 2010?
10.0- 9.6 per hunderd km.
I havent noticed any power diffrences tho?
Old May 8, 2011 | 07:38 PM
RazorLab's Avatar
Not the 2011 EDM roms.
Do you have some stock ones you can send my way?
Old May 9, 2011 | 04:12 AM
I'll get my felow auslancer.com admin to help me out . I shall have it for you soon
Old May 9, 2011 | 07:14 AM
Mad_SB's Avatar
Your point about the cams is totaly wrong. Plenty of 400whp BBXL cars running around on stock cams.... mater of fact.... the gains from MX-1's pail in comparison to an upgraded turbo. I know there are better cams out there but honestly cams would be one of the last things to upgrade.
If you're going with something bigger than a OEM Evo X turbo, you're going to need camshafts. Without cams, your gains over the OEM Evo X will be REALLY disappointing, with cams, you'll make about 380whp with a fp green and 420whp with a fp red. ....
Old May 9, 2011 | 04:30 PM
NICK(PMR)'s Avatar
Yeah i can organise that for you. Where you want me to send to?
