Trans Temp Gauge Location?
Old Aug 13, 2011 | 10:44 AM
Veronica's Avatar
I have some 160deg temp probes and gauges. Where would be a good place to externally mount them? Strapped to a cooler line?
And what about the turbo - same 160deg probe and gauge...
Old Aug 13, 2011 | 11:41 AM
Tommy Di Cat's Avatar
I have seen someone use the filler (galley plug) on the top of the trans. I used both oil galley plugs on my subaru block and it was very easy to install and accurate. I can't say for sure though.
Old Aug 13, 2011 | 11:54 AM
sstevojr's Avatar
You want to put a 160* temp gauge in the turbo??? It will be cooked in 2 mins flat....
Old Aug 13, 2011 | 02:13 PM
DaJackson's Avatar
Exactly, this is an EGT gauge which measures the heat of the gas right after the turbo. 160* would barely move the needle.
Old Aug 14, 2011 | 03:31 AM
Veronica's Avatar
Yeah.... I was thinking there might be a oil passage after the turbo or maybe i will just mount it in the bay...
I like the idea of an EGT Though!
Thanks!
Old Aug 15, 2011 | 07:21 PM
03chi-town0Z's Avatar
Farenheit or Celcius? If Farenheit, 160* isn't even high enough to cover the potential operating range of the transmission, let alone a turbo (which was mentioned already)
As far as mounting a sensor, I was looking at it myself and planned on using an adapter something like this in one of the drain-plug locations for an AEM temp gauge: http://www.autometer.com/cat_accesso...il.aspx?vid=58
Old Aug 17, 2011 | 08:50 AM
Veronica's Avatar
Fahrenheit.
Jovan Caro
Feb 22, 2017 11:04 AM
EndlessRed
May 8, 2009 04:29 PM
EvoIXMR
Nov 25, 2008 05:59 PM
mitsubishifreak
May 12, 2008 06:51 PM
mooreboost
12
Apr 21, 2005 08:37 AM
