cold start running rough
Old Jan 20, 2013 | 12:04 PM
zebra4's Avatar
I started my car this morning and it was about -34 degrees outside. I wasnt plugged in as i had to park on the street. It turned over slowly, and when it fired it sounded like it was running on 2 cylinders. It did this for about 10 seconds then stumbled and started running fine. I have a drop in filter, turbo back exhaust, boost pill and gst base map on 91. Obviously it was a symptom of the cold weather, but i am wondering what causes this and if it can do any damage.... this is the second time it has happened. I am more curious than anything. Thanks for any replies.
Old Jan 20, 2013 | 12:53 PM
crak's Avatar
maybe plug it in?????????????????????????? if you cant, well its going to do that when its cold outside. 90% of engine damage is from cold starts because of improper lubrication. Car was just hung over because it could move the oil properly through the engine.
Old Jan 21, 2013 | 07:16 AM
zebra4's Avatar
I normally plug it in every chance i get... but i was parked at a friends and had no way of getting a cord to it. It sounded like maybe a couple injectors werent firing at first. Thanks for the reply.
Omar Ramos
Jan 29, 2017 09:43 AM
asu11
36
Oct 15, 2016 12:25 PM
NelloMorto
Jul 15, 2012 09:10 AM
moss99
Feb 19, 2011 07:47 AM
rams3234
May 31, 2009 12:37 PM
