Dont know what the problem is
Old Nov 26, 2013 | 08:55 AM
jlog1506's Avatar
So the other day I was driving in 6th, dropped to 5th and went about 80% throttle and the car just cut boost and jerked. This has happened once since then, both times in 5th gear. Ive been running the gst base map for about a year and have had no issues until now. I also did a pull in 1st 2nd and 3rd and all pulled just a hard with no issues. Also I was in sport mode manual today and the car was shifting very slow. Any ideas? Thanks
Old Nov 26, 2013 | 01:15 PM
stfuad's Avatar
post some logs
Old Nov 26, 2013 | 02:38 PM
richardjh's Avatar
Which version Base Maps? The V30 and V31 Base Maps all have pretty safe boost control in high-gear, low-rpm situations.
At 2000rpm, 5th gear, the boost wastegate solenoid duty cycle (BWGDC) is less than 25%. Boost target is also low at that RPM point in that gear... like, under 13psi.
If you're running V30/V31, I can't see that "boost cut and jerk" being as a result of actual Boost Limit cut. Older V27 Base Maps, sure.
As above, post logs. If you can get 24/7 Standalone Logging working on Tactrix, it's pretty useful as a diagnostic tool. My vehicle logs itself on every trip. Haven't needed to plug in and check those mini-SD log files for over a year, but it's great to know they are there!
Rich
Old Nov 26, 2013 | 04:33 PM
jlog1506's Avatar
Rich
Im running v3, I don't have my tactrix right now as my friend has it. Im not very computer savvy as it took me days to flash it, so posting logs would be a challenge for me. But the funny thing is, it only happens sometimes, I guarantee If i go outside right now and did a fifth gear pull it wouldnt do it, but tomorrow it would. Both times this has happened it was in the higher rpm ranges, I would say 3500-5000The car just suddenly stops pulling, it almost feels like fuel cut as ive had that happen before(ran stock map with pill ) I live in NY so its very cold right now, would that have any effect?
Old Nov 26, 2013 | 04:50 PM
stfuad's Avatar
where in ny are you? if you're close enough I can take a look at it for you.
Old Nov 26, 2013 | 06:28 PM
Slee256's Avatar
Originally Posted by jlog1506
Im running v3
Get the latest version of the GST basemap on there my friend! Betcha it solves your problem.
Old Jan 11, 2014 | 10:28 AM
jlog1506's Avatar
I just upgrade to the latest map, went on the freeway, and it did the same exact thing.
Old Jan 12, 2014 | 07:41 PM
parralegend's Avatar
Just to clarify with this did the gear drop(go numb/neturalise) on you and it revved out.
I had it happend from 5th to 4th lucky i wasnt 100% punching it but it scared the s*** out of me and I've had it only ever happen once before into 4th not sure though it its a supersports flash related thing.
weeeeeeeeee
May 17, 2016 01:21 PM
Icegod87
Sep 24, 2014 04:48 PM
ddlopresti
Aug 22, 2014 07:40 AM
Evostacio
Dec 12, 2011 10:13 AM
EVO8LTW
Sep 7, 2010 03:44 PM
