Replaced all 4 tires. Now i get AWD service required!
Hey so i replaced all 4 of my tires and had an alignment done and had them adjust my camber on the front so my new tires wont wear on the outside anymore. Once i started driving it the service required for awd came on. I was able to clear it with my cobb tuner but it came back on the next day. Car drives fine and i dont notice any loss of power.
What could be the cause of this and how would I go about fixing it?
http://www.mitsubishicars.com/lancer/trims
Sorry about the profile. Not sure why i put gts ralli. Anyways its fixed i have a 2015 ralliart.
All tires are the same size diameter the rears are a little wider but same size diameter total as the fronts. My wheels are 1/2 inch wider in the rear.
https://tiresize.com/tyre-size-calculator/
1. Choose the tab "Tyre Size Comparison".
2. Enter your OLD tyre size as "Tire 1".
3. Enter your NEW tyre size as "Tire 2".
4. Press "Compare Tire Sizes"
5. Check "Circumference". Compare "Tire 1" and "Tire 2" results.
If they differ (they will), take your car back to the place that fitted mismatched front and rear tyres onto an AWD car, and ask them to fix their mistake. Be polite, but firm.
Good luck!
Rich
Good bye differentials.
Hes got time to save it still though.
I forget the tolerance on tire wear for "modern" awd cars but I believes it 3/32 on diameter or 3/64 max tread differential between tires.
When you think about that and the wider stance rear tires It's pretty safe to assume that's your problem.
We're assuming the AWD Service warning is circumference-related - fair assumption there, I reckon. If the fronts and rears were exactly the same diameter, the ECU wouldn't be whining about it.
Rich
Ive had the same size tire on my wheels since i got the car. My fronts are 19" diameter and 8" wide. Rears are same diameter and 8.5" wide. I had the same size tires on the front and back before. The rears were a little stretched obviously so i figure there was a difference there with overall diameter and i never threw a code.
The new tires have an overall diameter of 26.18 in the rear and 25.79 in the front.
A difference of only .39 inches.
Didnt figure that small of a difference would mess anything up.
Im gonna take it back to the shop today and see if they broke any sensors.
The service required doesnt always come up either so im not sure. No difference in driving habits either time.
Ill see what they say.
.39" is outta spec....read your owners manual
dynofrog
Nov 25, 2014 06:55 AM
Iowa999
Jun 22, 2013 10:54 AM
