P0171 Log Read Help?
Old Dec 5, 2022 | 08:23 AM
RoiTainMent's Avatar
Hey folks,
So recently my ralliart threw a code for being lean. I am using the same tune I have been using for quite a while (gst tbe, stock downpipe) and have never had issues.
I decided to dig into it and all the lines I checked seemed fine for vac/boost but maybe there is something I am missing?
Anyway I happened to have a log from almost a year ago with my fuel trims enabled so I took another one today just on my way to work. It looks like for whatever reason I have always had some crazy values and just never knew it. Anyone that is more adept at reading logs can you take a peek at them and see if there is anything I should be looking for mechanically? I have the updated fuses and confirmed the fuel reg hose is ziptied in.
Old Jan 1, 2023 | 12:14 PM
groowe's Avatar
You're not logging properly. Some values are implausible. Check your ROM addresses or just use RAX logging.
evo.matt
May 17, 2017 08:45 PM
rgar
Jul 6, 2010 02:21 PM
eXtreme-Speed
Jan 13, 2010 09:51 PM
Boostfiend
Dec 21, 2008 02:20 PM
sabastian458
Jun 12, 2008 12:00 PM
