Fuel trims
Old Jun 11, 2008 | 01:55 PM
sabastian458's Avatar
Fuel trims
Hey, I have an issue with my fuel trims I can not seem to understand. I have EvoScan (.99, 2.0, 2.1 & 2.2), MitsuLogger, and ScanTech. With the Mitsulogger and all of the EvoScans, my fuel trims all read identical: .1008 but with ScanTech they fluctuate and read like fuel trims should. I have tried deleting and reloading EvoScan many times but I can not get them to log correctly. Has anyone ran into this before? If so, what is the issue?
Old Jun 12, 2008 | 08:43 AM
bump for some help
Old Jun 12, 2008 | 08:46 AM
TouringBubble's Avatar
Try loading the previous ROM Will ... the one before we upgraded to the v.15 ROM for the P300.
EDIT :: To add some info ... this is the car I mentioned the other day in the other thread on fuel trims. The O2 Feedback reacts normally, but all 3 LTFTs stay at 0.
Old Jun 12, 2008 | 08:48 AM
Also, do you have a CEL?
Old Jun 12, 2008 | 11:11 AM
well, just before loading the new rom to fix the p0300, i stopped getting p0300.
then i went ahead and loaded the new rom and I now get the rear o2 sensor heater circuit, where as I didnt use to. I need to check the MIL again to make sure that is the only one. My laptop battery died a while back and I havent pluged it in yet
Old Jun 12, 2008 | 11:18 AM
Let me revisit the ROM and double check the rear O2 ...
Old Jun 12, 2008 | 11:41 AM
I think the p0300 was a fluke. I changed plugs, regrounded the coils (made a grounding kit right to the battery and chasis) and relocated the HKS DIL-2 and its ground. I havent had the p0300 in a while.
Old Jun 12, 2008 | 11:43 AM
Well, you shouldn't get it on the new ROM. You need to be on the new ROM anyway as it was a Mitsu update to your car, so let's work on it starting there.
Old Jun 12, 2008 | 12:00 PM
I will keep the newest rom loaded. I havent made may logs due to changing positions at work. I have cut my driving down by 2/3's or more.
evo.matt
May 17, 2017 08:45 PM
Evo_Matt
Feb 13, 2011 08:24 PM
ValdezeEvo
Apr 15, 2010 02:36 AM
RedLanEVO
May 24, 2008 12:17 PM
spdracerut
Apr 2, 2007 02:43 PM
