How To: Locate and Install Boost Pill
Old Jun 19, 2011 | 08:32 AM
  #46
crankIT's Avatar
ya, so right now I am using the 2 remaining clips to hold the hose on, nothing holding the boost pill in place. No problems yet. Will order new hose soon...
Old Jun 20, 2011 | 10:43 AM
  #47
03chi-town0Z's Avatar
I'd definitely recommend sooner rather than later. It may not be showing any issues at this point, but who can say what will happen in the long term, or even tomorrow. Peace-of-mind is well worth the couple of bucks for a spring clip, or just spend the 15 bucks for a new assembly.
Old Jul 28, 2011 | 01:13 PM
  #48
prozak's Avatar
OK guys, leave it to me, I was trying to do this install and dropped a clip. 2 metal on metal pings, one when it hit the heat shield, and one when it fell to the bottom of the engine bay. Anyone have a similar experience, where is the sucker, and what should I do? And no, its not under the car!
im sure you found it by now, but if it ever happens again, I have had great luck with the long telescoping magnets... they can get where your hands cant go...
Old Nov 14, 2011 | 05:11 AM
  #49
10Sportback's Avatar
Does the location of the pill in the hose matter? I mean how close or far from the Tee it is?
Old Nov 30, 2011 | 04:56 AM
  #50
BravoZero's Avatar
It should be a little less than an inch from the T- connector.
Make sure when reinstalling the boost pill that the bigger, open end faces upwards towards the outlet pipe, the smaller end facing downwards. Had a scare yesterday with this and reinstalled it backwards, overboosted and threw a bunch of codes. Reinstalled it correctly after that, car's running fine now.
Old Jan 24, 2012 | 07:06 PM
  #51
AWDralliart09's Avatar
AAH HA moment!! So simple.
Old Jan 28, 2012 | 11:13 AM
  #52
xDarKnighTx's Avatar
Are you talking about the boost pill, or the stock pill? I just received the AMS boost pill, and to me, both ends seem to be the same size. Does the orientation matter when you install the boost pill?
Old Jan 28, 2012 | 07:59 PM
  #53
BravoZero's Avatar
The stock pill, for anyone that needs to reinstall it.
The aftermarket boost pills are all similar, both ends are the same so it doesn't matter, but the OEM pill has two different ends.
Old Mar 5, 2012 | 05:35 AM
  #54
Esco!'s Avatar
Originally Posted by jazket
This junk is easy but I didn't see a How To and thought some people might benefit from this:
1- Locate the vacuum hose; The pill is inside this hose held by a clamp/clip.
2 - Remove the clips or just loosen them.
3 - With a small screw driver push the old pill out and put the new one back in.
4 - Tight everything back in place and voila.
Images:
Nice! I'll be using this on Wednesday, thanks!
Old Apr 3, 2012 | 08:34 PM
  #55
Seb15's Avatar
If i put the boost pill in and reflash the ECU with a GST map will work?
Cheers
Old Apr 3, 2012 | 09:21 PM
  #56
BravoZero's Avatar
Cheers
An aftermarket boost pill isn't necessary, you can flash the appropriate GST basemap for the stock pill. In order to get the most out of it though, I'd recommend getting one.
To answer your question, you simply install the boost pill, immediately flash the appropriate GST basemap and drive. DO NOT start the car on the stock ROM with an aftermarket boost pill, and vice versa... don't start the car on the GST basemap for a boost pill with the stock pill.
Old Apr 3, 2012 | 11:57 PM
  #57
Seb15's Avatar
Roger!
Thanks!
Old Jul 18, 2012 | 01:18 AM
  #58
tencents's Avatar
Does anyone know what size are the vacuum hose?
Old Aug 17, 2012 | 06:01 AM
  #59
marell31's Avatar
So.... After the pill and the Gst maps...... The car still passes the emmisions inspection??
Old Aug 17, 2012 | 09:39 AM
  #60
nunyas's Avatar
as long as you keep your emissions components in place.
