need help to install EVO X OEM IC
Old May 19, 2010 | 07:41 PM
Jack Dempsey's Avatar
Hi gents,
I was wondering how to fit EVO X OEM IC on my RA09+ using stock UICP & LICP. I read some threads about this topic but I didn't found an exact reply about couplers dimensions.
Do I need to replace stock coupler to fit RA09+ UICP on EVO X IC inlet?
What are the reducer dimensions I need to fit EVO X IC outlet to RA09+ LICP?
Thanks
Old May 19, 2010 | 09:33 PM
Cosis's Avatar
I have an extra evo X oem top intercooler pipe. If you dont want to mod, its an easy 50$ and ill send it to you. That way you dont need to mess around with couplers, keep a stock look, but will get a slight gain from the larger pipe.
Old May 20, 2010 | 07:19 AM
03chi-town0Z's Avatar
Originally Posted by Jack Dempsey
Hi gents,
Thanks
2.5" straight silicone coupler for i/c to licp
Old Jul 11, 2010 | 08:50 AM
chlucero's Avatar
Is taht all you need as far as couplers? Just the one for the LICP?
Old Jul 11, 2010 | 01:44 PM
yes, inlet will be reusable, but may need to be shortened a bit
Old Feb 20, 2012 | 08:53 PM
psikill's Avatar
about to do the x intercooler swap.
So to confirm. All i need are 2.5 -2.5in couplers (straight)?
Will be using RA stock pipes for now.
Thanks!
Old Feb 22, 2012 | 03:03 PM
ltn's Avatar
ltn
I believe if you keep the stock Ralliart LICP you need to get a 2.5 to 2.25 reducer or the couplers will blow off. I tried to ghetto rig my stock LICP and it worked for a bit but I ended up having to buy a reducer because the pipe kept blowing off.
Old Feb 23, 2012 | 06:26 AM
psikill's Avatar
Thanks will run to local performance store and grab the reducer!
Old Feb 8, 2013 | 06:29 AM
AVTuned's Avatar
how the hell do you guys get it to fit with the stock LICP with just a reducer coupler??
I tried that but the LICP is too long and If I fit the coupler it keeps pushing the FMIC to the passanger side, so it doesn't align and rubs the air conditioner radiator...
Im confused
Old Feb 10, 2013 | 04:14 PM
Rokpapaziz's Avatar
Im confused
I thought this too when I did mine.
My solution was to use a spare EVO X rubber upper intake pipe and cut it up to use as couplers, works great.
As for your I/C moving there should be 2 bolts on the bottom that bolts into the frame to keep it in place.
Old Apr 28, 2013 | 10:23 PM
Rex87's Avatar
Couplers aside how would I go about fitting the stock RA UICP to an Evo X IC, since the RA piping is longer. Would I need the Evo X UICP or an aftermarket one to fit?
Old Apr 29, 2013 | 08:12 AM
nunyas's Avatar
You'll need an EvoX UICP, or an aftermarket EvoX UICP. Or you could cut up your existing UICP to make it work (I don't recommend doing this).
Old May 3, 2013 | 11:13 PM
Rex87's Avatar
Yes, that does sound logical (not cutting).
I've acquired all the piping/intercooler for a full Evo X intercooler swap. Is the LICP direct fit into the RA? (It looks like there's slight differences in piping in this photo)
Old May 4, 2013 | 12:40 AM
nunyas's Avatar
it's almost a direct fit. you'll need to devise your own way to get the BPV to connect to it, which isn't too difficult. I believe there is a how to on it...
rallibiz
Dec 28, 2016 06:33 PM
russ72
Aug 24, 2015 08:20 AM
498001061
Dec 27, 2013 09:16 PM
EyeDreamt
Sep 22, 2011 05:51 PM
dD Spikey
24
Oct 18, 2009 08:06 AM
