Bumper no longer flush?
I took my front bumper off today do to an intercooler swap, and when I put it back on and bolted everything back up, I noted the very far corners of the bumper that meet the fender aren't flush anymore, they stick out badly. That top bolt isn't overtightened, all of the clips are in place... I don't understand. It's the same way on both sides.
It wasn't like this before and it's actually depressing. Any ideas???
My 2011 had the exact same thing happen. Except i have never taken the front bumper off. It does kind of suck but i have not had time to mess around it with it yet.
its caused by a clip being out of place. I have had this happen, and finally managed to find a clip put of place. lined everything back up, and hit it into place. Good to go . Don't force it though. once the clip you is lined you'll know it
I just changed my ic again. When I changed from the stock to the X went back on fine. This time I have a little gap under my driver side headlight and I cant figure it out either. Took it off and put it back on and its still there.
you have a square piece on your bumper, and a plastic clip(its pretty big u cant miss it) near the headlight, if that clip does not mount up with the square on the bumper then it wont line up and you will have that sag under the headlight. My clip for some reason seems almost like its worn, and wont latch on, So i have that small gap.
I made sure that the clip is in the black square under the healight and it still sags maybe its like what u said Blitz its worn out from thanking it on and off or maybe Ive been too rough with it when taking it off and putting it back on.
WTB[Mid-Atlantic]: Console Cubby Tray
Veronica
Feb 16, 2015 06:18 PM
BravoZero
12
Oct 2, 2011 09:18 AM
