Let's see YOUR track Evo
Old Jun 5, 2012 | 11:09 AM
  #526
Smike's Avatar
Originally Posted by EVOizmm
ATE does have that great of a wet boiling point.
One track that i seem to always have brake issues at is Blackhawk Farms. I've managed to boil fresh motul600 and ATE, once losing brakes and going off at turn 7 and the other time lost brakes in the pits right after getting off track. Both times were on a full street car, full interior and near the 300whp mark.
IMO:
ATE or Motul- work good for some LIGHT track use and autocross
SRF or Endless- The best, heavy track use.
Just so we're clear for all -- wet boiling point just means what the fluid will boil to at 3% water to volume of the system - 100 ml fluid = 3 ml water.
DRY boiling is the biggest concern. But hey, if you want to spend $80/L on SRF - more power to you. ATE/Amsoil/Motul are great too.
Ducts, ducts, cooling, ducts - makes/keeps brakes happy.
Old Jun 5, 2012 | 11:16 AM
  #527
EvoJoeRacing's Avatar
^im not sure i follow with that statement... are you saying a dry boiling point is more important then wet boiling point? If yes then im going to have to disagree with you
Old Jun 5, 2012 | 11:31 AM
  #528
Balrok's Avatar
May want to start a separate thread Smike and get one of the mods to move the related posts over.
Old Jun 5, 2012 | 11:35 AM
  #529
Smike's Avatar
Yeah, might have to...
There is my big stuck thread in wheel and tire on brakes and pads too.
Talking race cars - yep. Dry > Wet.
More on it:
http://www.afcoracing.com/tech_pages/fluid.shtml
Again, wet boiling point is when there is up to 3% water in the system. If you race...you best be changing/bleeding on a regular schedule anyway. Should be little to no water in the system. Unless you did the bled in the rain.
Old Jun 5, 2012 | 11:49 AM
  #530
PCSkiBum_21's Avatar
well all i can say is, bleeding ATE fluid every 2 sessions (20 mins) and it still would fade. SRF i bleed once every 2 track days (8, 20 min sessions) and haven't had any issues since. the amount of ate i cycled through easily cost as much if not more than how much srf i use. my .02 and real world personal experience, not just looking at numbers on paper..
i would say if your (anybody's) pad/fluid is not giving you any issues then just stick with it. "don't fix it if it "aint broke". huge +1 on proper ducting though!
Old Jun 5, 2012 | 11:52 AM
  #531
Smike's Avatar
100% that.
Old Jun 5, 2012 | 04:26 PM
  #532
EVOizmm's Avatar
are we going to start arguing about brake fluid coming in plastic bottles too? Lol
Brake fluid is cheap. I use ATE currently because my car see’s one lap at a time, not 20. If it did, I’d use SRF.
Old Jun 5, 2012 | 05:36 PM
  #533
Smike's Avatar
And the color of the bottles.
Old Jun 5, 2012 | 07:22 PM
  #534
EVOizmm's Avatar
well we could argue as to why the Super Blue is more than the Type200 when its the same dam shxt.
Old Jun 5, 2012 | 08:24 PM
  #535
ExViTermini's Avatar
Bro come on...it's blue vs yellow...hardly the same! lol
I'll be running motul rbf600 this weekend on 8 30 min sessions, hopefully things work out. I'm hardly the best driver, but I've gotten pretty decent with a Miata, trying my hand at the evo this round.
Old Jun 6, 2012 | 08:40 AM
  #536
haha yeah sorry about that, one last piece of cool info i just found this AM.
Arranged by Dry
DRY:401F -- WET:284F --- DOT3 MINIMUM (GLYCOL BASE)
DRY:446F -- WET:311F --- DOT4 MINIMUM (GLYCOL BASE)
DRY:500F -- WET:356F --- DOT5 MINIMUM (SILICONE BASE)
DRY:500F -- WET:356F --- DOT5.1 MINIMUM (GLYCOL BASE)
DRY:500F -- WET:???F --- FORD HEAVY DUTY DOT 3 PM-1C (new since 2006)
DRY:527F -- WET:302F --- AP RACING 551 ($12.799/0.5L OR 16.9 OZ)
DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4
DRY:536F -- WET:388F --- ATE SUPERBLUE/TYP200 ($13.99/1L)
DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 PM-1 (pre 2006) ($4/12 OZ)
DRY:570F -- WET:284F --- WILWOOD 570 ($7.95/12 OZ)
DRY:570F -- WET:284F --- PERFORMANCE Friction Z rated ($6.27/16 OZ)
DRY:572F -- WET:410F --- AP RACING 600 ($19.95/0.5L OR 16.9 OZ)
DRY:590F -- WET:???F --- TILTON TBR-1 ($11.95/0.25L) (new since 2006)
DRY:590F -- WET:518F --- CASTROL SRF ($74.99/1.0L 0R 33.8 OZ)
DRY:593F -- WET:421F --- MOTUL RBF 600 ($15.99/0.5L OR 16.9 OZ)
DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS ($19.95/0.5L OR 16.9 OZ)
DRY:608F -- WET:390F --- AP RACING PRF660 ($29.95/0.5L OR 16.9 OZ)
DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610 ($11.95/12 OZ)
DRY:613F -- WET:424F --- ENDLESS RF-650 ($33.00/0.5L OR 16.9 OZ)
DRY:617F -- WET:399F --- MOTUL RBF 660 ($28.99/0.5L OR 16.9 OZ)
DRY:617F -- WET:383F --- PFC RH665($28.99/0.5L OR 16.9 OZ)
DRY:622F -- WET:???F --- TILTON TSR-1 ($17.95/0.25L) (new since 2006)
DRY:626F -- WET:???F --- FERODO FSF050 Super Race Brake Fluid ($39.99/0.5L OR 16.9 OZ)
DRY:626F -- WET:417F --- WILWOOD EXP 600 ($18.99/0.5L 16.9 OZ)
DRY:635F -- WET:???F --- BREMBO HTC 64T ($32.00/0.5L 16.9 OZ)
DRY:635F -- WET:430F --- PROJECT MU G/FOUR 335 ($45.00/1.0L 33.8 OZ)
DRY:683F -- WET:439F --- PROSPEED RS683 ($39.99/0.5L OR 16.9 OZ)
Arranged by Wet
DRY:626F -- WET:???F --- FERODO FSF050 Super Race Brake Fluid (new since 2009)
DRY:617F -- WET:383F --- PFC RH665 (new since 2011)
DRY:683F -- WET:439F --- PROSPEED RS683 (new since 2010)
/threadderail.
engine is back in, rebuilt transmission and converted to LSD viscous coupler transfer case (front diff) since my ACD pump got smashed in the accident. also, machined billet motor mount inserts x4. what a PITA to get everything lined up with these, but totally worth it. power steering cooler mounted and new lines ran. moved oil cooler location, mounted and new AN fittings/stainless lines ran. more to come soon.
Old Jun 8, 2012 | 03:36 AM
  #537
ITOzann's Avatar
Excuse the tiny canard
Sometimes I'm too cheap.. specially when buying pictures :P
Old Jun 8, 2012 | 09:44 AM
  #538
Originally Posted by ITOzann
LOL, what is going on here
Great pics. Love the wide body track day EVO
What track is that (Infineon?)
Joe/ So.Cal
Old Jun 8, 2012 | 08:11 PM
  #539
EGbeater's Avatar
This thread is providing additional motivation to get my Evo back up and running already. I really want to see if my DIY aero mods I've been dinking with over the last few months will help my lap times at all... or if they'll just add weight and drag.
Old Jun 10, 2012 | 08:13 AM
  #540
gannieevo9's Avatar
Well, technically not mine but it was mine for two days this past week and has an evo heart....
