Let's see YOUR track Evo
Old May 22, 2012 | 02:25 PM
  #496
18bora's Avatar
Originally Posted by PCSkiBum_21
yep that was mine. i was going to sell it for an open wheel car, but then i hit the wall at mmp and decided to rebuild better and keep it.
http://www.youtube.com/watch?v=XUMwS...&feature=g-upl
http://www.youtube.com/watch?v=mCOnve50ggg
I had similar experience @ NJMP. http://vimeo.com/16484971 I found the video from the Porsche behind me titled, "Thunderbolt T1 - the EVO line" with a description "A unique line through turn 1, as performed by an EVO driver. I was impressed that he drove away after this maneuver with only a bruised ego. Those EVOs are tough cars!"
Before the event, I swapped my front calipers with a freshly rebuilt one and I guess I didn't bleed them enough. A huge air bubble decided to come out halfway during the second session, at the end of the front straight.
Old May 23, 2012 | 02:48 PM
  #497
PCSkiBum_21's Avatar
that's about the worst feeling in the world isn't it? how bad was it? glad to see it says you drove away.
Old May 23, 2012 | 02:58 PM
  #498
kanyonkid's Avatar
I've had pedal fade before but mild, it was weird this time it was no warning and just totally gone. I was just doing what I could to get it sideways and scrubbed off as much speed as possible. I'm doing about 120 before brake zone in that turn, I figured that I still hit the wall around 50-60mph though.
Pads were Hawk DTC-70, and ATE super blue fluid. Brembo GT355mm front kit, stock rears. So the bias is too heavy to the front right now. I since switched to Pagid pads and Castrol SRF fluid, and rebuilt the caliper seals and haven't had any more fade at all.
Literally exact same thing happened to me, over boiled my fluid at 120 coming into a 60 mph turn... first thing i noticed in the video was you constantly pumping that pedal. Just fast forward my video to 13.45 and see how we did the exact same thing. Luckily for me i didn't flip and had no wall to hit. Before this i had never had my brake pedal fail from boiling fluid. Glad you were ok! Nice setup too
http://www.youtube.com/watch?v=qXoM1...1&feature=plcp
Old May 23, 2012 | 03:18 PM
  #499
Sidnakit's Avatar
i wish i had a race car evo
Old May 23, 2012 | 04:21 PM
  #500
loofee's Avatar
Here's mine
http://www.csgoodphotos.com/Cars/201...qk8dx&lb=1&s=O
Old May 25, 2012 | 07:41 AM
  #501
Kidloco51's Avatar
Your wallet thanks you....
Old May 25, 2012 | 08:28 AM
  #502
EVOizmm's Avatar
2nd that!
Old May 25, 2012 | 01:09 PM
  #503
18bora's Avatar
It's not a good feeling for sure; everything was fine and I drove away, NJMP has a lot of runoff room.
Old May 25, 2012 | 08:33 PM
  #504
justboosted02's Avatar
ive lost my brakes on the main straight at the glen ( ~150mph). luckily they have a lot of runoff that is paved so i was able to save the car without incident.
I was running amsoil brake fluid and have since switched to SRF. SRF is amazing stuff
Old May 29, 2012 | 09:00 AM
  #505
SRF is hands down the best racing fluid evar. it's about 4x's more $$ than ATE, but the boiling temp points are way better. I have a friend using Amsoil Series 600, which is about same price as ATE and should be a bit better too.
ATE Super Blue: Dry (536F), Wet (388F)
Amsoil Series 600: Dry (580F), Wet (410F)
Castrol SRF: Dry (590F), Wet (518F)
The wet is heads and shoulders above which is awesome. If you get the brakes a little too hot once or twice, you will definitely get oxygen in the system, which leads to water in the system. Obviously if you get water in there you are going to boil them over again really easy. The extra $60 or whatever is totally worth it IMO.
Old May 29, 2012 | 09:46 AM
  #506
meltdown's Avatar
Any downside to using SRF in a daily driver that occasionaly sees track days?
Old May 29, 2012 | 07:35 PM
  #507
Evolution IVGSR's Avatar
I have the ATE Super Blue in the past and was going to switch to the Motul RBF600 Brake Fluid Synthetic DOT 4 on my new car. It has a boiling point of Dry (593F), Wet (420F) It is also under $20 so not as pricey as the Castrol SRF but its still better than the ATE Super Blue and Amsoil for the close to the same price.
Old May 29, 2012 | 08:34 PM
  #508
Kidloco51's Avatar
I run Motul fluid and have never had an issue (I beat the living **** out of my brakes, check my build thread). I boiled ATE when I ran it
Old May 30, 2012 | 05:46 AM
  #509
EVOizmm's Avatar
Motul is a little over 2X the price of ATE.
If you run at 9/10ths for 15+ minutes, spend the extra money on the BEST fluid, SRF. its a small price to pay to insure you have brakes at every corner.
Old May 30, 2012 | 07:55 AM
  #510
jid2's Avatar
Anyone want to buy an unopened bottle of ATE?
