Bulb size chart (LED ready)
Old Oct 2, 2012 | 08:58 PM
Juz10 xD's Avatar
Low beam:
With OEM HID D2R Reports of D2S in 2013+ vehicles, please double check your bulb before ordering
With OEM HALOGEN H11 You must order H11 based HID's if doing a conversion, D2R will NOT work
High beam: 9005
Fog: H11
Front markers: 168
Turn signals (front and rear): 7440
License plate: 168
Reverse: 921
Front fender sidemarker: 168 Unconfirmed, Service Manual claims the bulbs are not replaceable, that the entire unit must be swapped out
Trunk: 3022 (30mm festoon) Burtonrider1002's '11 SE AWC has a 168 bulb, check yours before ordering
Map/dome: 3175 (31mm festoon)
Tail/brake lights are incorporated LED
License plate bulbs you want a forward facing or 360 degree, the bulbs point downwards into the housings, onto the plate. If you go 360 degree, line the inside of the housing with either aluminum foil or white tape, not sure which one works best yet but I've tried foil which had a clean, even spread of light.
I'm personally more fan of the 5k white which will match the oem bmw/lexus/etc white. The 6k white seems to be a bit blue and doesn't output as bright.
I recommend using products from www.vleds.com
Be mindful of their "output rating" scale to determine which to buy.
OP's links to his recommendations no longer worked due to V-LED's changing their website around.
A few other helpful threads:
https://www.evolutionm.net/forums/ou...ight-bulb.html
https://www.evolutionm.net/forums/ou...r-hid-kit.html
https://www.evolutionm.net/forums/ou...lb-change.html
Also an option is to modify an H9 bulb to work in your H11 socket for more light output: http://udanis.com/h11-to-h9-headlight-conversion/
This post has been slightly reorganized for easier readability and updated by Burtonrider1002. The original information provided by Juz10_xD is in black
Old Oct 2, 2012 | 09:27 PM
sikwititevo9's Avatar
Do you have any pics that you can post with the lights on so we can see them in action?
Old Oct 2, 2012 | 09:31 PM
Juz10 xD's Avatar
no not at the moment, but i just ordered these so after the install them, i will take shots. i'm only doing the interior and license plates for now.
http://www.v-leds.com/Universal-LED/...-p9494324.html
i've used other types of leds in different cars though so I can also take shots of those when i get a hold of the cars.
Old Oct 4, 2012 | 10:09 PM
vdubdave's Avatar
I installed the LEDs in my cars interior this evenining and it was quite simple. Just use a small flat head screwdriver and pop out the plastic cover. Remove your light bulb and replace. All done. It made a HUGE difference.
Old Oct 14, 2012 | 08:12 AM
Pelka's Avatar
The fender signals are 168 if I'm not mistaken correct? And on my 2012 the HIDs from factory where D2S.
Old Oct 14, 2012 | 10:53 PM
Burtonrider1002's Avatar
EvoM Moderator
Yes.
from the OP: "Front markers 168"
Old Oct 15, 2012 | 11:23 PM
EvoM Moderator
Also, I ordered a pair of dome lights, reverse lights, and license plate lights from V-LED's. Shipping is VERY reasonable! Most places still charge an obsurd amount for little items, but my total was $3.XX for shipping to 60612.
The reverse lights I bought are on clearance right now for $17 a pair. That is a REALLY good price for 921 bulbs. SuperbrightLEDs has them for about $17 EACH. Reviews on them were excellent also. With my dark tint I could use the extra lighting when backing.
I'm excited, and I'll try to post some before/after pics or vids for you guys.
Old Oct 16, 2012 | 03:13 AM
EVO KING's Avatar
I just built mines very simple and super super bright none of these leds compare to mine because all these led side markers are cool but they are not super visible in the day these leds 168 led are only 1.5w well mine are 5w which no one sells not even ebay so they are super visible even in the day check it out ill post more vids later
Old Oct 16, 2012 | 10:23 AM
EvoM Moderator
http://www.youtube.com/watch?v=Wvt8d...&feature=g-upl
Well... bragging is cool and all, but a how-to on how to build them or an offer to sell them would be more useful. As-is I don't have the time, knowledge, or resources to build my own bulbs. Due to this, the V-LED's seem like the best option. If you have a better solution that is still cost effective and doesn't negate my reasons above, I'm all ears, because those do look nice and bright.
Old Oct 26, 2012 | 03:38 PM
EvoM Moderator
V-LEDs installed, will post a better review late tonight. First off, the interior map light bulbs are amazing, even though I accidentally ordered the wrong ones. I meant to order the "high output" ones, but somehow grabbed the regular ones instead. That actually makes these things MORE impressive in my book, I'd imagine the high output ones are just fantastic. The fit is a little bit tight, but wow are they brighter and better. Day it's noticeable, but at night it's amazing. I will get the H/O for my center roof light and report back on the difference
THESE 921 reverse bulbs suck IMO. I think my stockers were brighter. These will be removed and returned. Luckily they took about 45 seconds per bulb. Next I'm going to do the license plate bulbs, I just gotta figure out how to get the cover off them.
Old Oct 30, 2012 | 02:13 PM
Juz10 xD's Avatar
license plate light housings come off by pushing the whole housing to the passenger side to release the tab on the drivers side and then let it drop down.
Old Oct 30, 2012 | 11:39 PM
EvoM Moderator
Oh, yeah, sorry, I figured that out after posting. I just saw the "tabs" on the one end and assumed it needed to be pushed/bent with a screwdriver, but I didn't want to break anything lol.
Thanks though!
Old Mar 8, 2013 | 08:00 AM
Evo11V's Avatar
Veteran: Army
you get get pictures of these?
Old Mar 8, 2013 | 06:58 PM
EvoM Moderator
Left is OEM, right is LED. I can take a picture of it with both LED's in if you want.
(please forgive the dirty car, I actually wash it at least twice a week, these were taken during a snowstorm lol)
Old Mar 8, 2013 | 07:16 PM
4drboost's Avatar
What brand of led are those and where can I purchase it?
