All Part Number Request Go Here
Old Oct 23, 2004 | 07:51 AM
  #166
mitsupwr's Avatar
vortex generator part#MZ380295EX
Old Oct 24, 2004 | 01:15 AM
  #167
JustDSM's Avatar
Thanks mitsupwr. I'm swamped with work at the moment and have not had the time to look this info up for the board users.
Old Oct 30, 2004 | 07:57 AM
  #168
freedom's Avatar
What is the part number for the '03 Evo's clock?
Old Nov 2, 2004 | 07:37 AM
  #169
JustDSM's Avatar
The GSR, RS, and MR all share the same cylinder head and camshafts. Part numbers are listed below:
Cyl Head: MN155744
Intake Camshaft: MN143619
Exhaust Camshaft: MN143620
Intake Manifold: MN137746
Exhaust Manifold: MN156302
Down Pipe: MN135583
Mid Pipe: MR968097
Rear Section: MN153192
I've already pointed this out elsewhere on the forums but the MR does in fact use a revised (larger) compressor housing compared to the RS/GSR trims. Everyone is already well aware of the turbine housing.. All models do in fact use the same CHRA however.
CHRA: MD613507
'03-'04 All Trim levels
Compressor Housing: MD613567
Turbine Houshing: MD613521
All '05 Trim levels
Compressor Housing: MD613573
Turbine Housing: MD613524
***Please note that the MR turbine housing uses the same O2 housing as the previous models. You do not need to purchase a "MR" housing.
MR Wheel (17x8JJ +38): MN184113
Old Nov 2, 2004 | 07:45 AM
  #170
JustDSM's Avatar
MR962799
Old Nov 3, 2004 | 12:59 PM
  #171
gbpkr21's Avatar
Well. I changed my oil again, and this time I bought ramps so I did not spend 2 hours removing the plastic undercover....anyway, the part number on the oil filter on the MR was MD356000. The oil filter I bought from Mitsu was MZ690116. I compared them and #MD356000 was a little smaller than #MZ690116. I put the new one on, and it fit perfect. Which is the right one? I will probably continue to use #MZ690116 just because it is a little larger. Just curious....
Old Nov 3, 2004 | 01:02 PM
  #172
marksae's Avatar
Hmm... are the 05s' undertray different than the 03s? I don't need to take it off to do an oil change.
The original filter off my EVO was MD356000 also. Mitsu recently switched to newer style oil filters across the board, so the original off your car was the old style. All new replacement filters are MZ690116.
Old Nov 3, 2004 | 01:32 PM
  #173
gbpkr21's Avatar
I took the tray off the first time because I am dumb. I could not find a place to jack it up, so I removed all of the undertray (like a dumb ***) to clear a spot to jack it up. This time I bought ramps and the oil change took ~ 20 minutes.
Thanks for the filter info!!
Old Nov 7, 2004 | 09:15 AM
  #174
GreedMOTO's Avatar
Part number for the plastic housing arount the clock and hazard switch. It holds two vents too. Broke it mounting display for EVC.
Old Nov 8, 2004 | 01:58 AM
  #175
JustDSM's Avatar
MR512557
Old Nov 8, 2004 | 11:02 AM
  #176
lacartus's Avatar
Question Fog lights and switch
I bought an '05 without the foglights. Anyone know the part numbers required to install them?
-- switch
-- relay?
-- housing for foglight...I hope the whole headlight assembly doesn't have to be replaced.
It will be interesting to see how much I can get this from Conicelli...I guess it might be cheaper to buy aftermarket lights and put them below the bumper somewhere.
TIA,
Old Nov 9, 2004 | 04:22 PM
  #177
GreedMOTO's Avatar
Originally Posted by JustDSM
MR512557
Thanks! ------>for your effort ----------->
Old Nov 10, 2004 | 09:32 AM
  #178
Event-Horizon's Avatar
OK. Can someone explain to me why the EVO's that come from the factory have FULL carbon Fiber spoliers. Yet, the replacement spoiler my dealer got had plastic ends? I want a factory original, is this possible? The spoiler that came on my car was all carbon fiber and you can see the weave under the paint.
Can someone PLEASE find me a mitsu part number for the REAL carbon fiber spoiler that I can take to the dealer so they can order me the right one.
Old Nov 10, 2004 | 10:18 AM
  #179
sillypuddy's Avatar
Last time I compiled a list of all part numbers so far (that way we can see it all in one shot, instead of reading 8000 posts), I can do it again or if somebody else wants to take a turn? =)
-joe
Old Nov 10, 2004 | 11:04 AM
  #180
sillypuddy's Avatar
i was bored.. so here's all the part numbers so far:
MR633538 Upper Steering column cover
MR232147 Gear link bushing
MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts
MR572609 Board, trunk room floor
MR444269 Trim, Trunk room RR end (Grey)
MD050316 Oil drain plug
MD569372 M/T plug
MB547806 Clip, Engine Room Cover
MZ690116 oil filter
MR552951 air filter
MR407376 Front pad kit (hardware sold separately)
MR407391 rear pad kit " "
MD979313 water pump
MN158794 alternator belt
MD186785 spark plug grommets
MD340535 valve cover gasket
MD152772 pcv valve
MN132206 clutch disc
MR980846 pressure plate
MR145619 T/O bearing
MD746617 clutch slave cylinder
MR491945 clutch master cylinder
MN149074 crankshaft pulley
MR370723 front brake rotors
MN153010 oxygen sennsor frt
MR578532 rear oxygen sensor
MD327107 cam position sensor
MR578117 knock sensor
MD363552 ignition coil
MD343245 plug wires set
MD374841 spark plugs
MR455707 lug nuts
MB911495 wheel studs (frt or rear)
MR984375 timing belt adjuster
MD369999 timing belt pulley
MD569372 air intake rivet thingy
MR288876 hood vent rivet thingy
MR975089 coin box
mn153356 BODY ASSY,AIR CLEANER (Stock Airbox)
mr578399 SENSOR,AIR CLEANER (MAF SENSOR)
MN153284 bov
MN126274 Insulator, Hood
MR475929 Left caliper
MR475930 Right caliper
MZ598263 CD Changer Install kit
MR626799 cd changer panel only, no rails (black)
MR554814 RH Lower Control Arm Asm.
MR554813 LH Lower Control Arm Asm. (this is an assumption based on left right part#)
MB914617 Front Wheel Bearing Asm.
MD160689 1G Air bypass valve (for anyone using Buschur upper IC)
MU480007 licence plate grommet (square)
MN168249 Gear Shift Lever Retainer (part of the gearshift level)
MR286178 Replacement trunk lock
MR633547 panel with the shifter and ashtray and the cigarette lighter
MN161463 RS ~04/07/31 trunk lid
MN161464 RS 04/08~ trunk lid (no spoiler)
MN150620 RS 04/08~ trunk lid (spoiler)
MN161462 MR trunk lid (spoiler)
MN161463 MR trunk lid (no spoiler)
MR574731 front Mitsubishi symbol
MR975477 intake/trunk carpeting fastener
MB547806 front undertray fastener
MB918617 tiny light that shines into the ash tray
MN143213 stock boost solinoid located under the airbox
MR412407 rs trunk bar
MN101890 MR bilsteins Fronts
MN101899 MR bilsteins Rears
MR647677 the piece that holds the ashtray and the cig lighter
MD372536 cam seals
MN158794 Alternator and other drive belt
MN153284 MR bypass valves
MR970228 black RS door handles Front Right
MR970227 black RS door handles Front Left
MR970268 black RS door handles Rear Right
MR970267 black RS door handles Rear Left
MR450703 donut gasket for the downpipe
MR481252 radiator cap
MR250558 Radio delete panel
MR597271 downpipe bolts
MR597273 downpipe Springs
MR497545 studs on the cat
MR571083 downpipe -> cat (nuts that go on the studs on the cat)
MF241309 cat -> cat-back bolts + nuts
MR627152 interior door handle Front Left
MR627153 interior door handle Front Right
1545A001 MR BOV
MD345681 Rocker cover center cover
MN161534 rear side marker light
MR648031 rear interior door panel (which side?)
MR973540 antenna Base
MR583214 antenna Nut
MR587268 stock radio (evo?)
MD000312 transmission drain plug gasket
MF660036 trasmission fill plug gasket
MD000312 transfer case drain plug gasket
MD000312 transfer case fill plug gasket
MB001294 rear diff. drain plug gasket
MF660036 rear diff. fill plug gasket
MR506482 headlight height adjustment switch
MN126920HB 3rd stoplight cover (You have to get the whole light assy.)
MR580533 teflon shifter cables MR
MN107670 teflon shifter cables GSR/RS
MN143079 timing belt cover lower front
MN153353 Air Cleaner box cover (top)
MD613573 MR Specific Compressor housing
MD613524 MR Specific Turbine housing
MD613567 GSR/RS Specific Compressor housing
MD613521 GSR/RS Specific Turbine housing
MZ380295EX vortex generator
MN155744 Cyl Head
MN143619 Intake Camshaft
MN143620 Exhaust Camshaft
MN137746 Intake Manifold
MN156302 Exhaust Manifold
MN135583 Down Pipe
MR968097 Mid Pipe
MN153192 Rear Section
MR962799 03 Evo's clock
MD356000 MR oil filter
MZ690116 oil filter (normal?)
MR512557 plastic housing arount the clock and hazard switch
-joe
