All Part Number Request Go Here
Old Jan 10, 2005 | 05:25 AM
  #331
sillypuddy's Avatar
The list so far:
MR633538 Upper Steering column cover
MR232147 Gear link bushing
MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts
MR572609 Board, trunk room floor
MR444269 Trim, Trunk room RR end (Grey)
MD050316 Oil drain plug
MD569372 M/T plug
MB547806 Clip, Engine Room Cover
MZ690116 oil filter
MR552951 air filter
MR407376 Front pad kit (hardware sold separately)
MR407391 rear pad kit " "
MD979313 water pump
MN158794 alternator belt
MD186785 spark plug grommets
MD340535 valve cover gasket
MD152772 pcv valve
MN132206 clutch disc
MR980846 pressure plate
MR145619 T/O bearing
MD746617 clutch slave cylinder
MR491945 clutch master cylinder
MN149074 crankshaft pulley
MR370723 front brake rotors
MN153010 oxygen sennsor frt
MR578532 rear oxygen sensor
MD327107 cam position sensor
MR578117 knock sensor
MD363552 ignition coil
MD343245 plug wires set
MD374841 spark plugs
MR455707 lug nuts
MB911495 wheel studs (frt or rear)
MR984375 timing belt adjuster
MD369999 timing belt pulley
MD569372 air intake rivet thingy
MR288876 hood vent rivet thingy
MR975089 coin box
mn153356 BODY ASSY,AIR CLEANER (Stock Airbox)
mr578399 SENSOR,AIR CLEANER (MAF SENSOR)
MN153284 bov
MN126274 Insulator, Hood
MR475929 Left caliper
MR475930 Right caliper
MZ598263 CD Changer Install kit
MR626799 cd changer panel only, no rails (black)
MR554814 RH Lower Control Arm Asm.
MR554813 LH Lower Control Arm Asm. (this is an assumption based on left right part#)
MB914617 Front Wheel Bearing Asm.
MD160689 1G Air bypass valve (for anyone using Buschur upper IC)
MU480007 licence plate grommet (square)
MN168249 Gear Shift Lever Retainer (part of the gearshift level)
MR286178 Replacement trunk lock
MR633547 panel with the shifter and ashtray and the cigarette lighter
MN161463 RS ~04/07/31 trunk lid
MN161464 RS 04/08~ trunk lid (no spoiler)
MN150620 RS 04/08~ trunk lid (spoiler)
MN161462 MR trunk lid (spoiler)
MN161463 MR trunk lid (no spoiler)
MR574731 front Mitsubishi symbol
MR975477 intake/trunk carpeting fastener
MB547806 front undertray fastener
MB918617 tiny light that shines into the ash tray
MN143213 stock boost solinoid located under the airbox
MR412407 rs trunk bar
MN101890 MR bilsteins Fronts
MN101899 MR bilsteins Rears
MR647677 the piece that holds the ashtray and the cig lighter
MD372536 cam seals
MN158794 Alternator and other drive belt
MN153284 MR bypass valves
MR970228 black RS door handles Front Right
MR970227 black RS door handles Front Left
MR970268 black RS door handles Rear Right
MR970267 black RS door handles Rear Left
MR450703 donut gasket for the downpipe
MR481252 radiator cap
MR250558 Radio delete panel
MR597271 downpipe bolts
MR597273 downpipe Springs
MR497545 studs on the cat
MR571083 downpipe -> cat (nuts that go on the studs on the cat)
MF241309 cat -> cat-back bolts + nuts
MR627152 interior door handle Front Left
MR627153 interior door handle Front Right
1545A001 MR BOV
MD345681 Rocker cover center cover
MN161534 rear side marker light
MR648031 rear interior door panel (which side?)
MR973540 antenna Base
MR583214 antenna Nut
MR587268 stock radio (evo?)
MD000312 transmission drain plug gasket
MF660036 trasmission fill plug gasket
MD000312 transfer case drain plug gasket
MD000312 transfer case fill plug gasket
MB001294 rear diff. drain plug gasket
MF660036 rear diff. fill plug gasket
MR506482 headlight height adjustment switch
MN126920HB 3rd stoplight cover (You have to get the whole light assy.)
MR580533 teflon shifter cables MR
MN107670 teflon shifter cables GSR/RS
MN143079 timing belt cover lower front
MN153353 Air Cleaner box cover (top)
MD613573 MR Specific Compressor housing
MD613524 MR Specific Turbine housing
MD613567 GSR/RS Specific Compressor housing
MD613521 GSR/RS Specific Turbine housing
MZ380295EX vortex generator
MN155744 Cyl Head
MN143619 Intake Camshaft
MN143620 Exhaust Camshaft
MN137746 Intake Manifold
MN156302 Exhaust Manifold
MN135583 Down Pipe
MR968097 Mid Pipe
MN153192 Rear Section
MR962799 03 Evo's clock
MD356000 MR oil filter
MZ690116 oil filter (normal?)
MR512557 plastic housing arount the clock and hazard switch
MR954150 Right (Passenger Side) Front Fender
MN161172 Right (Passenger Side) Complete Entire Light (Including Housing, HID) (this is the entire assy.)
MR954176 Right (Passenger Side) Front Wheel well Plastic Dirt covering
MN161277 Hood
MS240129 Bolts for gas tank and rear trunk tie bar
MR572500 Clips for the rear trunk liner
MN151260HA MR Mats (both sides?)
MN126980 Front bumper undertray
MN161109XA Black front bumper cover
MN156784 O2 Housing
MR299686 Metal Gasket to Turbine <-- parts to go with the O2 housing
MD132933 4 x Washer
MD062961 3 x Bolt
MR224441 1 x Stud
MD050073 1 x Nut
MN101464 MR Front springs (same part # as GSR/RS)
4140A007 MR Rear springs
MR538851 Fog Light relay
MB914617 Front wheel hub assembly
MN153285 front mount intercooler
MN126784HC Lower lip of front clip (comes pre-painted)
MN126771 intercooler grille
MN126979 Left Undertrays w/ brake cooling ducts
MN126980 Right Undertrays w/ brake cooling ducts
MR379950 Center Undertrays w/ brake cooling ducts
MN126784 HC (Pre-painted) EVO8 FRONT AIRDAM LIP
MN126981 PANEL UNDERCOVER FRONT
MN126979 PANEL UNDERCOVER FRONT CENTER
MZ530857 Mud Flap Kit Carbon (Evolution)
MZ530855 Mud Flap Kit - Red (Ralliart)
MR109421 diamond trunk badge for a 1999 Galant.
MR631941 Left a-pillar
MR631943 Right a-pillar
MR370729 lower front caliper bolt
MR407072 lower front caliper washer
MS240121 Air box bracket bolts
MS240142 overflow bolts
8011A017 MR Sticker
MD748267 Evo 5 transfer case (inc helical LSD)
MN155760 03-05 head gasket
MR578634 02 lancer 0Z Front Oxygen Sensor
MR507854 02 lancer 0Z Rear Oxygen Sensor
MR795453 02 lancer 0Z switch blank cover
MR573539 02 lancer 0Z Plastic Tabs that go in door handles (left)
MR573544 02 lancer 0Z Plastic Tabs that go in door handles (right)
MR627179 02 lancer 0Z Plastic Trim Ring for Passenger Side Rear Door Handle
MR497518 02 lancer 0Z Air Intake Ram Air Piece
MR233903 USDM cigarette lighter
MR506482 USDM headlamp tilt angle switch
MR627178 02 lancer 0Z Plastic Trim Ring for Driver Side Rear Door Handle
MN161109RA Rally Red Bumper Cover
MN126784RA Rally Red front airdam lip
MN126772 Lower metal mounting bracket for the front intercooler grill
metal mounting tabs that secure the mesh grills to the bumper:
MB325298 10 pieces needed
MR447202 2 pieces needed
MN161109WA White bumper cover
MN126784WA White air dam
MN143343 hose line for the blow off valve
MR385780 heat shield bolts
MF434103 MAF sensor nuts (4 pieces needed)
MS820976 fog light housing
-joe
Old Jan 10, 2005 | 07:26 AM
  #332
spoolingEVOx's Avatar
Joe,
Just a question: is that a typo or are the part numbers from the "Right Undertrays w/ brake cooling ducts" and "Front bumper undertray" supposed to be the same (MN126980)?
I am concerned because I am replacing some undertray components and am curious. Thanks.
Old Jan 10, 2005 | 09:19 AM
  #333
JustDSM's Avatar
I'll have to get back with you in tomorrow to confirm. I'll re-post each of the undertray's PN#'s.
Old Jan 10, 2005 | 10:50 AM
  #334
sillypuddy's Avatar
sorry, i just go through all the posts so far and condense them down to a list..
i figure instead of everybody asking the same part #, they can see if it's on the list first
but if it's wrong, please speak up and i will change the desc of the part to make it work better
-joe
Old Jan 10, 2005 | 10:00 PM
  #335
one more part number request..
the e-brake handle/assembly (not the cable, just the knob and rubber boot).
i'm going to try and have custom leather e-brake boots made for us, but i need to purchase an e-brake from mitsubishiparts.net first.
thanks guys, you're the best and this thread was a brilliant idea.
Old Jan 11, 2005 | 09:13 AM
  #336
JustDSM's Avatar
I'll get back to you in a few hours. I'm without my laptop at the moment.
Old Jan 11, 2005 | 10:01 AM
  #337
thanks Justin
Old Jan 11, 2005 | 09:58 PM
  #338
JustDSM's Avatar
the e-brake handle/assembly (not the cable, just the knob and rubber boot). MR628249 w/ a build date from 1Dec02-3Dec03
MN102750HA w/ a build date from 1Jan04-3Jul04
MN102750HB w/ a build date from 1Aug04-Present
There you go.
Old Jan 12, 2005 | 02:39 PM
  #339
humpevo311's Avatar
p# for japanese mr tails
Does anyone have the oem part number for the japanese mr taillights? or even the standard evo7 tails. Thanks.
Old Jan 20, 2005 | 10:55 PM
  #340
Doug@WGP's Avatar
part # for the stock fuel pump housing ? (The white plastic case w/ the three openings)
Old Jan 21, 2005 | 04:43 AM
  #341
JustDSM's Avatar
MR571545
Old Jan 23, 2005 | 02:15 PM
  #342
can you tell me what the part numbers are for the pieces circled below in red?
thanks!!
Old Feb 3, 2005 | 06:07 PM
  #343
LateSleeper's Avatar
JustDSM,
Do you have the part number for the Pressure Plate bolts?
See the attached pic. I have the bolt circled in red.
Thanks.
Old Feb 5, 2005 | 10:49 AM
  #344
JustDSM's Avatar
Originally Posted by LateSleeper
JustDSM,
Thanks.
Sorry for the late response. But here is the part #: MF241251
Old Feb 5, 2005 | 10:55 AM
  #345
JustDSM's Avatar
thanks!!
You'll have to forgive me on the delayed response. Since this thread was "unstuck" I sometimes overlook it.
Anyway. Here are your requested part numbers:
Front bumper cover section (white): MN126723WA
Front bumper clips: MU488006
Note: The clip that was depicted on the side of the front bumper. It looks like its the same one used as the ones on the bottom of the cover. CAPS lists 10 are needed.
HTH
