DynoFlash [Visit Site]
Alcohol kit install photos and directions
Old Mar 22, 2005 | 02:41 PM
  #61
NYEVO8's Avatar
Originally Posted by DynoFlash
You dont need anything otrher than the kit - a retune flash is also helpful though
al, are you saying that this will work with stock exhuast system, i dont think you can get too much hp if any out the stock exhaust and WI.
or are you saying no mods other than the basic, like, 3" tbe and boost controller.
Old Mar 27, 2005 | 01:31 PM
  #62
E1's Avatar
E1
NO...no...i think he say you need to do something ..1st before this kid go in...
Old Mar 27, 2005 | 02:17 PM
  #63
DynoFlash's Avatar
Itw ill work =- but a retune would be needed t yild any power from alcohol injection
Old Mar 27, 2005 | 02:52 PM
  #64
lil'evil_evo's Avatar
Why would you run this kit before a tbe?
Old Mar 27, 2005 | 05:15 PM
  #65
NYEVO8's Avatar
thats what i am saying i find no reason to run this kit without the basic mods, such as 3" tbe and boost controller. i think anybody with a total stock car is just wasting their money on this kit.
i was just trying to clear up something that was said earlier in this thread, someone asked how would this kit be on a stock car. i think they should do other mods first and then WI.
i dont want al to lose a customer but i think the person that asked would be wasting his money, if this is going to be his first mod.
Old Apr 30, 2005 | 04:12 PM
  #66
vividevoVIII's Avatar
Question Nozzle ?
Al,
I just installed my kit, and I think I have the latest generation, the one with the guage at the nozzle.
anyways, I installed the nozzle and I tightned it down very tight, the washer on the inside of the IC pipe is compressed a lot. But, the top side were the tee is with the guage and the incoming line, there is no washer. Therefore it is virtually impossible to get a seal on the top side. When I started my car, I put little spit around the tee where it meets the piping, and there is a small pin hole leak. When I test drove it, it seemed to hold boost, which I know is vaccum.
Is it going to be a problem with that slight leak. I haven't ran alcohol yet, because I have to get tuned first, but when alcohol is being sprayed, do you think it will leak out?
thanks,
Old Apr 30, 2005 | 06:20 PM
  #67
EVO8LTW's Avatar
I'd be interested in seeing closer pictures of how that nozzle mounts. Someone else mentioned an issue with having trouble with the seal and suggested welding in a bung. If that's a better way to go, it'd be worth paying someone 1/2 hour labor to weld up a bung.
Old May 17, 2005 | 04:44 PM
  #68
Evoryder's Avatar
is it really neccessary to replace the head studs...i'm about to finish up my meth install and want to get it tuned by you on the 1st ...
do the studs now or will u install it for me ??
Old May 18, 2005 | 02:49 PM
  #69
Evoryder's Avatar
my Trunk "meth kit " set up ...
Old May 18, 2005 | 09:21 PM
  #70
redevo561's Avatar
wow thats clean bro im getting mine installed and tuned by al also im installing head studs as well better be safe than sorry 100 buck is worth it instead of a head gasket blowing on you. my car looks exactly like yours but i have tint's
Old May 20, 2005 | 08:51 PM
  #71
EVO8LTW's Avatar
Is that the SMC trunk-mount set-up? How did you route the alky line to the engine compartment? Does it run under the body of the car? How big is the tank?
Old May 20, 2005 | 09:17 PM
  #72
BigLEVO's Avatar
al....i know you had this special quite some time ago but that was $1000 installed and tuned for the kit? still running that special? please let me know thanks
Old May 21, 2005 | 12:34 PM
  #73
Evoryder's Avatar
how much is a typical install for head studs? ...
...tints are coming soon...
Old May 21, 2005 | 12:41 PM
  #74
Evoryder's Avatar
It's the SnowPerforance Stage1 kit ..."Boost cooler" i ran the wires under the car..zip tied them ...good distance from exhaust ...car runs better with the meth on...needs tuning though...just making my fuel mix even richer...here's another pic ..gonna get a 7qt tank soon...that one is too small...
Old May 23, 2005 | 12:02 PM
  #75
redevo561's Avatar
typical install if you are getting the cam's installed the same time is 1 hour of labor depends on the company thats doing the job that charges hourley
