DynoFlash [Visit Site]
Alcohol kit install photos and directions
Old Feb 18, 2005 | 07:40 AM
  #46
DynoFlash's Avatar
Originally Posted by SuperchargedGTZ
Al,
Have you dynoed your car yet with the alcohol?
Yes - do a serach - 622 whp on pump gas - a record I think
Old Feb 18, 2005 | 07:57 AM
  #47
gourry's Avatar
will this work with a regular lancer?
Old Feb 19, 2005 | 07:29 AM
  #48
DynoFlash's Avatar
We have a kit that will
Old Feb 19, 2005 | 08:14 AM
  #49
gourry's Avatar
well i am getting the rippmods stage 2 kit, so will this affect it in anyway. thanks Al for any info.
Matt
Old Feb 19, 2005 | 08:19 AM
  #50
gourry's Avatar
sorry to double post, what other mods/parts am i going to need to do this.
Old Feb 22, 2005 | 03:51 PM
  #51
DynoFlash's Avatar
You dont need anything otrher than the kit - a retune flash is also helpful though
Old Mar 18, 2005 | 12:23 PM
  #52
Yaroslav's Avatar
AL any difference between your and AMS WI?
Old Mar 21, 2005 | 05:28 AM
  #53
Jon H's Avatar
Anyone have this installed using the stock IC piping? Did you tap the rubber elbow or the aluminum piping?
Old Mar 21, 2005 | 05:37 AM
  #54
tcarretti's Avatar
I had this installed last week on a stock IC pipe into the aluminum piping. I went for dyno tuning this weekend and was not able to tune for the alky kit because under pressure it was leaking at the nozzle. Thank God it was a 50-50 mix or I might have burned down right there on the dyno. I think it would be safest to have a hard IC pipe and then have a bung welded into it so that the braided line could be better seated. Now I'll have to wait until I get the whole thing fixed before I can even look into having it tuned.
I'm pretty disappointed but I realize that it's not a defect in the alky kit. It's just not the best way to tap into the IC piping. Just my .02 cents.
Tony
Old Mar 22, 2005 | 05:24 AM
  #55
EVO8LTW's Avatar
Why is there a difference tapping the stock piping vs. aftermarket piping? Aren't they both metal/hard?
Old Mar 22, 2005 | 05:43 AM
  #56
tcarretti's Avatar
Yes, they're both hard but now my stock pipe has a hole in it. Also, if I go with an aftermarket pipe, I am reducing some bends, getting rid of the lousy stock hose sections and hopefully be able to get the nozzle closer to the throttle body. With a bung welded in place there will seem to be a less likely chance of something working it's way loose also. At least I'm hoping so. Only time will tell.......
  #57
smackdaddy's Avatar
been wondering how it was going to go tapping into an aluminum pipe. I'm thinking I might have to through some jb weld on it as well.
Old Mar 22, 2005 | 06:26 AM
  #58
NYREDEVO's Avatar
What kind of gains would you expcet on a stage 2 Buschur w/alky? Is running alky the same basically as running race gas (power wise) ?
Old Mar 22, 2005 | 07:35 AM
  #59
EVO8LTW's Avatar
Buschur tested this very thing on the dyno thread -- alky on Stage 2. I can't remember the result, but I think it was 20-30 hp. Do a search.
Old Mar 22, 2005 | 12:37 PM
  #60
Jon H's Avatar
Al states that running 100% alcohol is equivilent to running C-116 in the tank.
