DynoFlash [Visit Site]
Alcohol kit install photos and directions
Old Jun 2, 2005 | 07:09 PM
  #76
eric yong's Avatar
what is the cost for the kit and how much is to met or alcohol
Old Jun 7, 2005 | 06:56 PM
  #77
mooreboost's Avatar
1) Do you think headstuds can be safely installed without pulling the head?
2) Are there any safeguards in your flash to protect the engine if the alcohol stops flowing?
3) I have read from a very prominent tuner that you should run the lowest octane fuel that you do not detonate on, because you will make the most power that way. With that in mind, would it be best to mix water and alcohol until you get a mix that prevents detonation, but still has water in it?
Old Jun 7, 2005 | 08:39 PM
  #78
tcarretti's Avatar
There are people that say you can install the head studs one by one but from talking to a few mechanics the general consensus is that even by doing one at a time, the seal on the headgasket is still being broken, albeit a tiny bit. They've seen a few cars running hotter than stock and believe that this was the common denominator.
Bottom line is it worth it to you to take a chance and then have to turn around and do it all over again and possibly damaging your motor?
Weigh the risks...... the car's not cheap!
Old Jun 8, 2005 | 02:20 AM
  #79
Zeus's Avatar
I've yet to see a "failure" with the studs installed one at a time on a stone cold engine, including on my own Evo. However, to each their own...
Tony, I'm still ironing that thing out we talked about... looks REAL good!
Old Jun 8, 2005 | 10:05 AM
  #80
Chris@nolimitmotors's Avatar
changing one stud at a time when the car is off and cool is fine. maybe if u took one out and boosted it up to 20 psi you might lose the seal a little bit, but once the car is cool down its fine.
Old Jun 8, 2005 | 10:52 AM
  #81
mooreboost's Avatar
Originally Posted by Zeus
I've yet to see a "failure" the studs this way this way, including my own Evo. However, to each their own...
By "this way" do you mean the one by one method?
Old Sep 18, 2005 | 10:34 PM
  #82
XxBLACKMAMBAxX's Avatar
I have a couple of questions about running alcohol. I am interested in buying this kit but want to know if running the kit richens the AFR mixture much like C16 fuel does? My whole issue is, I dont want to HAVE to run the alcohol at all times, meaning I dont want to be reflashed for the alky kit and be running too lean without it on. I want to keep my flash tune as is for my current mods and tune my SAFC2 for the alky and switch maps whenever I feel the need to run high boost and alky. Will this give me the same gains people are seeing with the alky by doing it this way?
Old Nov 12, 2005 | 05:02 PM
  #83
EVO8LTW's Avatar
HERE is another way to run the wire inside the car without drilling or running the harness to the passenger side of the firewall:
Old Apr 27, 2006 | 05:37 PM
  #84
EvoMike's Avatar
Veteran: Air Force
I posted in wrong thread, sorry.
Old May 16, 2006 | 06:28 PM
  #85
ohthree's Avatar
I dont know if this has been answered yet but Yaroslav asked aswell. Does the AMS water injection work with your reflash? thanks.
Old Jul 20, 2006 | 07:15 AM
  #86
AF-Evo8's Avatar
I have stock UICP will this be an issue?
thanks
David Buschur
Dec 26, 2018 10:40 AM
mishimoto
Mar 28, 2014 01:28 PM
evilution8
Mar 3, 2008 06:49 PM
afeudale
Lancer How Tos / Installations
Feb 20, 2008 10:55 AM
AutoMotoSports
Automotosports - Illinois
93
Feb 23, 2005 01:01 PM
