How To: Install a Zeitronix Wideband
Old Feb 23, 2007 | 12:00 PM
EVOpacoIX's Avatar
I had this WB in my eclipse, nothing but good things to say about it. And the install is very easy. Nice write-up.
Old Feb 24, 2007 | 12:29 PM
EVOBrad's Avatar
+1 - I used this as a guideline to install my ZT2 over the weekend. Thanks cij911!
Old Feb 24, 2007 | 12:31 PM
cij911's Avatar
Your welcome...Glad it helped...
Old Mar 10, 2007 | 09:28 PM
Whoop_ass's Avatar
guys one ? here!!
i want to get the Zeitronix but with boost and EGT as well.
How easy is it to read the LCD readout for Boost!
does it refresh quick enough or should i just a needle type guage as i feel they
are easier to read!
your thoughts on this??????????
Old Mar 10, 2007 | 11:27 PM
FastAzzEvo's Avatar
Originally Posted by Whoop_ass
guys one ? here!!
are easier to read!
You wanna see, how about realtime my man..
of course this is laptop logging not that expensive display, just buy the zt2 without the display and use a laptop or buy a $40 palm pilot
Old Mar 11, 2007 | 12:49 PM
Whoop_ass's Avatar
i know you can view in realtime but would it move as quick as an guage.
on my STi i had one of those PSi 3 units and they did not refresh very quick at all!
thats why i am asking
i am just thinking it is maybe easier to see a moving dial than a digital readout.
i would like to hear from someone that actually uses the Zeitronix as a boost guage.
thanks
Old Mar 11, 2007 | 12:55 PM
FastAzzEvo's Avatar
thanks
i do use my zt2 as a boost gauge, it is way more accurate than a boost gauge. it actually better for reviewing and tuning. You can't look at a boost gauge or a monitor while driving, or should i say its unsafe to.
Old Mar 11, 2007 | 08:07 PM
Zeitronix's Avatar
Whoop,
The plot on the laptop screen "moves" much faster than a guage. 74 times per second to be exact. Zt-2 outputs each value at such fast speed. You can adjust the numeric refresh value to your own perception speed.
Zeitronix Eng
Old Mar 11, 2007 | 10:09 PM
Whoop_ass's Avatar
Zetrionix thanks for the all the replies and info!
See it just makes more sense to have one of these units instead of 3-4 guages
doing the same job
so you saying that the LCD will refresh and change data at 75 samples per second
which is quick enough!!
thanks
Old Mar 11, 2007 | 11:25 PM
TTP Engineering's Avatar
It refreshes many times faster than your brain can even process the info.
Old Mar 12, 2007 | 12:26 AM
Zeitronix's Avatar
I was referring to the laptop screen logging 74 data points per second. You want logs to refresh fast since you are able to go back and analyze at a slow speed or even point by point. The LCD refreshes 3 times per second, which is a good rate for human perception.
Old Mar 13, 2007 | 06:39 PM
cij911's Avatar
I personally would recommend getting an inexpensive boost gauge (e.g Autometer) that you can see with your peripheral vision and get the MAP sensor for logging and tuning. The MAP sensor will be crucial to see what your real boost is and then once tuned you will know the characteristics of the boost gauge and know if there is ever an issue (e.g. boosting low)...Also, my autometer gauge is extremely accurate based upon my ZT2 logs.
Old Mar 18, 2007 | 07:33 PM
mplspilot's Avatar
some pics
Everything took about 4 hours with no rush.
Some maybe helpful info:
- The hole is just a tad too small, takes about 3 minutes to make it slightly bigger with a file.
- 22 mm wrench for o2 sensor.
- Get the splicers from radioshack, made by 3M for 18-20 gauge. Don't waste money on a boomslang.
- Radioshack also has hook-and-loop (plastic velcro) things i used to mount the screen.
Attached Thumbnails How To: Install a Zeitronix Wideband-wideband4.jpg   How To: Install a Zeitronix Wideband-wideband8.jpg   How To: Install a Zeitronix Wideband-wideband15.jpg   How To: Install a Zeitronix Wideband-wideband27.jpg   How To: Install a Zeitronix Wideband-wideband14-custom-.jpg
Old Mar 19, 2007 | 06:13 AM
CarFanatic's Avatar
great pics!!!
Old Mar 19, 2007 | 06:31 AM
There are only 5 taps needed for zeitronix. There are more taps pictured that I wanted to make clear are not required for use with the Zeitronix unit.
