How To: Install a Zeitronix Wideband
I kindda figured out my problem but i dont know how to fix it. The driver is not properly being installed. i try to update it and it says it cant find the necessary software. what do i do?
+1 to a great write up
my install took about 4 hours....
and that was while i was at work and helping customers too......plus i soldered and heatshrunk everything
also mounted mine in the RS in the little pocket they give you where the radio should be....
gotta solder! Such a simple but effective unit. I took mine off for a few days and i almost lost my mind...Once you go wideband, you never go back.
In all actuality, using quality 3m connectors offer a fast install with reversible uninstall option leaving little to no traces of any connections even being on the wiring harness.
even if i dont agree with your wiring standards
I'll back you up Kris I HATE THE QUICK CONNECTS! but if you are uncomfortable with stripping and soldiering that go ahead has for me everytyhing is Stripped, Poked, twisted and Soldiered.
-Joey D (4 year First Class MECP Installer)
guys, if I am going to install an any other WB which needs a ground location and 12V can I still use the ECu pins for ground and 12V ?
my wide band instructions ask to ground to the engine block.. but I think the ecu seems like a good spot (LC-1)
