How To: Install a Zeitronix Wideband
Old Nov 19, 2008 | 09:29 PM
  #106
Evoryder's Avatar
Originally Posted by Dream Came True
Can someone please check and confirm this is the right tapping for Evo 8 ECU?
Red -12 (12V Switched Power Supply, or any other 12V source)
Green - 58 ( Tach Signal)
Black - 26 (Chassis Ground, or any other ground)
Brown -92 (Sensor ground)
Grey - 84 (Throttle Position Sensor Signal)
http://www.zeitronix.com/installatio...structions.pdf
http://www.roadraceengineering.com/e...-ecuwiring.htm
Old Nov 19, 2008 | 10:08 PM
  #107
Dream Came True's Avatar
I basically looked at both link and came up with the list. I just wanted to confirm with someone who've already done that. Plus, it will be usefull for Evo 8 people for future reference.
Old Nov 20, 2008 | 06:02 AM
  #108
Evoryder's Avatar
Oh ok?..yes it's correct..
Old Mar 2, 2009 | 10:01 PM
  #109
cij911's Avatar
Anyone installed the ZAVT1, relay, and boost solenoid? I have a few questions about the relay and solenoid wiring....
On the relay :
(1) #85 goes to the white wire coming off the ZAVT1 (will that be hot or grounded when the trigger is met??)
(2) Do I connect #86 (12v+) to a switched power source? (or does this become 12V+ when the alarm / trigger is met)
(3) #30 do I need to ground this?
(4) #87a and 87 ?? What are these used for?
Thanks
Old Mar 3, 2009 | 10:50 AM
  #110
TTP Engineering's Avatar
On the relay :
Thanks
87a removes power, 87 gets power. when triggered. 87a can be snipped off.
30 and 85 get 12v.
86 goes to ZAVT-1 white output as we discussed on the phone yesterday.
87+ when triggered goes to BCS bypass 12v + with the other side grounded.
Old Mar 3, 2009 | 12:20 PM
  #111
Evoryder's Avatar
The white grounds the zavt when trigger settings are met.
Old Mar 3, 2009 | 01:02 PM
  #112
cij911's Avatar
Thanks Evoryder and Scott (TTP), but now I am more confused (the info conflicts each other)...
Old Mar 3, 2009 | 01:32 PM
  #113
cij911's Avatar
30 and 85 get 12v.
OK now I am more confused...Zeitronix instructions say :
Pin #4 (White) goes to negative side of the relay (which it depicts as 85)
It also shows 86 as going to 12v+
But 30, 87, and 87 a it says nothing....
So it appears TTPs/ Scott's numbers don't sync with Zeitronix which is why I am so so so confused....Please help clarify / correct.
Old Mar 3, 2009 | 01:48 PM
  #114
cij911's Avatar
deleted
Old Mar 3, 2009 | 02:03 PM
  #115
cij911's Avatar
delete duplicates
Old Mar 15, 2009 | 08:34 AM
  #116
cij911's Avatar
So I finally installed and setup the ZAVT1. I tested the simple condition to see how it works (basically set boost >=18psi) and it definitely killed boost, beeped, and light flashed. The odd thing is the ZAVT1 does not appear to hold the 'trigger' for 4 seconds -- I was holding throttle at 100% and it seemed to immediately starting building boost and then alarm triggered again vs. just keeping boost at WG (~14psi).
Is this configurable or does this sound normal?
My complex formula is :
Boost >= 19 psi
TPS >= 75%
Lean AFR >=11.8
Thoughts?
Old Mar 15, 2009 | 08:55 AM
  #117
Boost >= 19 psi
TPS >= 75%
Lean AFR >=11.8
Thoughts?
It is user configurable under warning/triggers catagory from and instantaneous cut to a user defined number of seconds. To have it cut for 4 seconds, you need to enter 4.
Old Mar 15, 2009 | 02:51 PM
  #118
cij911's Avatar
Scott -- Any idea why I cannot select anything in the Alarm Properties box (v2.0.18) ? I see where I should be able to increase duration but it is not an active box for some reason.
Old Mar 15, 2009 | 02:54 PM
  #119
Zeitronix's Avatar
Go to help, make sure the Zt-2 is tuning and connected to the PC. What is the entire product code? 2.0.18.?
Old Mar 15, 2009 | 07:20 PM
  #120
cij911's Avatar
Product Code: ZDL-2.0.18.11 ; Device: Zt2
Still not able to change the alarm duration....Thanks for your help.
