How To: Install a Zeitronix Wideband
Old Mar 22, 2007 | 02:09 PM
  #46
merkzu's Avatar
Good info, used it this morning. Only thing I noticed is you have pin 46 and 49 labeled backwards, 49 is sensor earth and 46 is power ground.
sticky!
Old Mar 22, 2007 | 03:12 PM
  #47
CarFanatic's Avatar
ok thats what I figured! I gotta buy one.
Old Mar 22, 2007 | 03:15 PM
  #48
CarFanatic's Avatar
sticky!
so then should when I install it should be
7. black ecu pin 49 power ground
8. sensor ground ecu pin 46
that right? Or are they the right wires, but he just mislabled them?
Old Mar 22, 2007 | 03:25 PM
  #49
TTP Engineering's Avatar
Sensor ground 49.
The main point is to have different grounding locations, but I would go by the book with brown zeitronix wire to 49 on an EVO IX only.
Old Mar 28, 2007 | 02:05 PM
  #50
merkzu's Avatar
the how-to has the wires right, just mislabeled
Old Apr 18, 2007 | 06:32 AM
  #51
CarFanatic's Avatar
quick question I went to install the software on my lap top, and it wouldn't install. Is there a trick to installing it? When I click on the install it didn't do anything?
Old Apr 21, 2007 | 08:40 PM
  #52
CarFanatic's Avatar
I bought a usb to serial port adapter and I cant get it to interface with the softare. What com port or changes do I need to make to get it to read?
Old May 8, 2007 | 03:09 PM
  #53
VenomEVO8's Avatar
Did your adapter come with a Cd for the drivers.. took me a day to figure out that there was a CD with my adapter... It will work after you do that
Old May 9, 2007 | 10:42 PM
  #54
sleet's Avatar
Originally Posted by cij911
Now find the ECU wiring diagram and make yourself VERY familiar before continuing. Attached are two links for the 8 and 9...Before tapping into the ECU wires disconnect the negative battery terminal (10 mm bolt).
Evo 8 -- http://roadraceengineering.com/evo/t...-ecuwiring.htm
That link is messed up, can you fix it?
Old May 10, 2007 | 04:30 AM
  #55
cij911's Avatar
Sorry, it is not on my servers....My walk through should answer all of your questions though...
Old May 12, 2007 | 02:39 AM
  #56
Whoop_ass's Avatar
i am gonna be installing mine soon
thanks
Old May 13, 2007 | 07:59 AM
  #57
lancerrally45's Avatar
Im trying to install my zeintronix wideband on my 02 lancer oz and i cant find any pin numbers that i have to splice into. I know the ecu is different in the evo but i was wondering if anyone knew what signal wires go were
thanks fo the help
Old May 13, 2007 | 08:52 AM
  #58
cij911's Avatar
thanks fo the help
Look at RRE's site. I believe they have PIN readout for the Lancer...
Old May 13, 2007 | 10:10 AM
  #59
I am unable to find it, on that website
Old May 13, 2007 | 10:19 AM
  #60
Evoryder's Avatar
just for you sleet
