fpevo green dyno numbers
Old Jul 5, 2007 | 10:02 PM
  #1021
RazorLab's Avatar
Some data from my personal Evo, Denso 720cc injectors:
3rd gear @ 7031 rpm = 94.5% IDC (at 24.57psi)
3rd gear @ 7562 rpm = 95.18% IDC (at 23.22psi)
4th gear @ 7094 rpm = 93.83% IDC (at 23.61psi)
4th gear @ 7500 rpm = 94.28% IDC (at 23.99psi)
11.5-11.6 afr - 100 octane
Old Jul 5, 2007 | 10:59 PM
  #1022
Faust's Avatar
I am still on my OEM Injectors and I'm holding 22-23 psi. And from what my tuner said I am just barely maxing them out. Pretty crazy.
Old Jul 6, 2007 | 02:17 AM
  #1023
V8HAHA's Avatar
Ithink Imight go with the buschur 780cc injectors based on what you guys are saying. Are buschur injectors good or what. I know they drive and build fast cars but I dont know anything about their injectors
Old Jul 6, 2007 | 04:13 AM
  #1024
mikesevo8's Avatar
I'm sorta in your boat - kinda confused . I don't see my injectors get maxed out. I wonder if I should be concerned...
I have Greddy 660s (Densos). Running 93+alky, and the largest IDC I have seen in my logs is 80% at 7K at 26psi; A/F at 11.2.
MAF freq was 2100Hz. This is the only logged event I have that relates to air flow.
Do you guys that max out these "smaller" injectors have any porting work done to increase total flow ???
Old Jul 6, 2007 | 06:50 AM
  #1025
CBRD's Avatar
this car is on a fairly conservative tune.... not as lean as i run most of them.... 350whp on our dyno on pump at 22.5psi.....lots of torque....
injectors are going in shortly... faust has been kind enough to let us experiment a little with the setups on his car.
cb
Old Jul 6, 2007 | 10:08 AM
  #1026
sparky's Avatar
Originally Posted by razorlab
.... Denso 720cc injectors:
Bryan: Do you have IDC data for the 720Žs from your 26 PSI dynorun? Did that totally max them out?
Old Jul 9, 2007 | 10:30 AM
  #1027
Erik@MIL.SPEC's Avatar
Just wanted to post my numbers. My car was a little sensitive, so Bryan had to be careful with the timing @ peak torque. The S1 cams set at -1/-2 result in slightly slower spool-up but the car rips up top. Most hp for a Green on 91 that they've had there so far
91 OCTANE:
BOOST AND AFR:
100 OCTANE (added 10 gallons of 100 to almost 1/4 tank of 91):
BOOST AND AFR...What taper? (gotta love the GM solenoid):
The car absolutely rips. 1st gear is ridiculous
Old Jul 9, 2007 | 11:19 AM
  #1028
trinydex's Avatar
beeutiful
Old Jul 9, 2007 | 11:35 AM
  #1029
Exciting News's Avatar
Did you do a pull @ 0/0? Curious how much your powerband shifted with those settings and how much, if anything, you had to give up for that power up top.
That is a nice torque curve. No doubt about it...
Old Jul 9, 2007 | 11:50 AM
  #1030
Didn't have a chance to mess with cam gear settings. We may be able to help spool-up if I can make my car less sensitive to knock. I am presently working on some solutions
Old Jul 9, 2007 | 11:57 AM
  #1031
joedr's Avatar
EvoM Moderator
Good numbers for 91 OCT. Congrats on your setup!
I have very similar setup on a IX. We will see how 93 OCT and MIVEC respond on a Dyno. I should have the S1s installed soon! Check my signature!
Old Jul 9, 2007 | 12:04 PM
  #1032
EVOLex's Avatar
Very impressive numbers!
Old Jul 9, 2007 | 12:09 PM
  #1033
sparky's Avatar
Nice numbers, congratulations. IŽll be up in L.A. starting on the 20th. IŽll give you a call, cause I want a ride in that thing.
Are you still using the XEDE to tune it? YouŽll have to get it up over 22# to really see a marked difference with that turbo. I got an extra 14 WHP(according to DataLogLab) by increasing boost just one pound(from 22# to 23#) and installing fresh plugs and cleaning the airfilter.
To get rid of some initial knock(about 4*)at WOT we pulled out .5* of timing at 3000-5000 RPM and an additional 1* from 5000 RPM to redline. Also, to help out upon throttle tip-in IŽm running -2/-3 cam timing as per TedB.
Setup this way I get Absolutely zero knock from WOT till redline at 23 PSI on 91 octane, with a safe 10.8 AFR at redline. Congrats on your Mustang Dyno numbers .
Old Jul 9, 2007 | 12:11 PM
  #1034
Thanks. I just realized that my AFR's are only around 11.2 on 100 octane. I think there is some room left
Old Jul 9, 2007 | 12:14 PM
  #1035
No, I switched over to ECUflash because I wanted the GM solenoid controlling boost. Well, considering these numbers are only @ 21 pounds I can't imagine 22 or 23
Something is banging somewhere, because when Bryan was shifting gears on the dyno I would get 1-2 counts of knock. Like I said, I am addressing that issue(s) presently as I have some ideas what it could be like:
Downpipe hitting oil pan
Exhaust tapping rear swaybar
Stiffer engine mount transferring vibration
