2009 Ralli Art Featured in Sport Compact Car Magazine
If you have enough money you can go to the junkyard and rip out S-AWC from a X and fit it onto a Evo VIII or IX, because a CT9A Evo test mule from Mitsu had S-AWC. That would be extremely stupid for an average/not rich person even if you try to do that on the RA. I wish I was rich. Damn it. I'm pretty sure as time goes by when more and more people wreck their Xs someone will try to install S-AWC into a RA.
Here you guys go. I did my $4.76 + labor in EvoM community service.
http://www.yourfilehost.com/media.ph...r_Ralliart.pdf
Thanks man i checked Walmart, Borders, Target, Grocery stores with no luck at all
Does not seem to have really info outside of the stuff that we already know though.
Of everything they could have said, Road Race chose that tired and heavily debated quote on how a modified FWD Lancer hung with an STI in a ghymkhana with the same driver. Lame. Talk about the turbo, talk about AWD, talk about tunability. Don't recycle the same old crap that made everyone get into a massive argument in the first place.
also the main difference between X and RA is S-AWC/AYC. that is VERY tough to simulate. the heroic handling that S-AWC/AYC gives you is something totally different than stiffer rear sway bars and crap like that.
as for the IX vs RA, the IX is still lighter than the RA and steers quicker. better stock suspension. a good used IX costs the same as the RA anyways so no value in the RA.
The VI (non-TME) is lighter and steers quicker than the IX and had inferior technology but the IX is faster. So anyways a good used VI can be had for less than a IX (if you live outside the US) so there is no value in the IX.
The IX is lighter and steers quicker than the X and had inferior technology but the X is faster. So anyways a good used IX can be had for less than a X so there is no value in the X.
another aspect of "handling" is brakes. with the evos you don't necessarily need to upgrade anything until you get serious. the RA is gonna require expensive big brake kits to match the evo's stock brake set up.
Most of the handling and performance equipment will be replaced and improved upon anyway. So your point is moot.
face it, to make it better than an evo, might as well just have bought an evo... IF YOU CAN. if your whole intent is to make an evo killing RA then you'd be dumb, dumb, dumb.... if you just wanna pimp your RA then cool, just don't act like you tuned RA is better than an evo cuz with 1/4 of the money you spent to get there, the evo will convincingly surpass that mark.
You sound like a little kid. Damn, I hate elitist children.Thanks for your lame opinion, though. I could care less about it. It won't be better than the X that's for sure. I'll do whatever I want, though.
quite frankly... YES! if it was supposed to be some handling monster why give it GTS brakes and suspension (albeit probably with a bit stiffer suspension settings). i can see no brembos stock, but not an option either? no option of eibach springs or bilstein dampers, forged lightweight wheels, etc. the car has good handling stock but not evo-like handling. this is obviously for cost cutting and product planning/market placement reasons. so what you end up with is a good STREET machine where you don't need to pull lateral g's and stop on a dime. what you need is a good gearbox, which it has, and a punchy quick spooling engine, which it has.
the USDM IX handles great but it's not magic. sticky tires, good suspension, great steering, good brakes, etc. the JDM IX handles even better: less weight & AYC.
but the RA will undoubtedly have merely adequate brakes and suspension stock and it weighs a ton, relatively. it's NOT destined for greatness as a race car but as a street car? HELL YES!
i was talking about the X and like i said, even to match a IX you'd have to spend some considerable dough and at that point the cost of RA + suspension would give you a car that handles just as well but is still slower. if your intent was to beat it, guess what? you still lose.
Putting the S-AWC is deffinitly not worth it for the $$$. The RA has a lot more room in the trunk due to no AYC. If the trunk is different you can bet the subframe is different. So to fit the S-AWC you will have to change to the entire evo suspension, brakes, body, subframe, diff, ecu, sensors, cut into your trunk, etc.
I personally think the RA will handle good enough for 95% of the people on the road. I live in the USA and a straight line car with some above average handling is fine with me.
weight reduction? like what? you gonna strip the car out so you can be better than an evo? or you gonna take out the trunk lining and save 5 lbs? get real...
I don't care. The feel will be different between the X's handling compared to the RA's, I agree. But it's possible to equal the stock X's speed with stiffer rear sway bars and crap like that. I don't care about matching the feel of S-AWC. You forgot to mention coilovers and other crap. But mod for mod the X will always be faster.
what a ricer. all you care about is numbers? handling is now reduced to numbers and feel has nothing to do with it right? man this guy is some funny sh*t
http://youtube.com/watch?v=3YG3uoadVgk
the VI TME is the BEST evo ever made. MOST people would agree.
and if you haven't noticed by now yes the IX is faster than the X. dollar for dollar if you want speed, the IX wins. how hard is this to understand? are you 12?
Did you know that most cars now a days have very good brakes? Even stock Civic brakes are really good. Just swap the pads and rotors, put in stronger brake lines, better brake fluid, add cooling ducts and vents. That will be enough to race with. Other than the cooling ducts and vents the rest of it you will replace anyway. As for the RA, I'll just jack the Brembos off the X for almost free at the junkyard or get something better.
my point was that you're gonna be spending money to try and match the evo. when you tally up the total, i HIGHLY doubt you'll end up spending less than just buying an evo.
With that logic, it would mean all older Evo owners are dumb, dumb, dumb, bum, bum, bum, because their Evos are slower?
You pretty much described a JDM Evo RS. You're becoming lamer and lamer every time you type. You need to stop fan boy. Look up how a JDM Evo RS is. It does not have Brembos, they have steelies (the ones you put hubcaps over), no AYC, and no Recaros. The reason why it comes with inferior equipment is because people will replace them for something better anyway.
Read the article about Project WRX V.08 in the July issue of Sport Compact Car. It's on page 86. It's a comparison between a stock 07 STI, stock 08 STI, and a modded 08 WRX. Guess who won? They did not spend much with that car. It has handling and power mods. I think they spent less than what a brand new 07 STI cost. That's car plus mods and tuning.
don't believe everything in magazines. did they list prices for parts, shipping, labor, and tuning/dyno time? did they mention that they get paid to do this and that you'd have to eat up free time to do this? or even take off work and in essence lose even more money? c'mon. not everything in life is cut and dry like in a magazine. i'm done with you. you are ignorant and too stupid to know that you are. grow up.
and how labor intensive do you think that would be? do you have ANY idea how much money "simple" swaps such as these cost? parts plus labor. like i said this isn't a 10 minute job. maybe you're rich or maybe daddy and mommy have deep pockets but you sure aren't very realistic. go back to gran turismo...
I'm not rich. I'm going to do things I can afford when I can afford it. The build will be a long and gradual process. If I can't afford it than whatever. I'll move on. My posts have been expressing the idea that things can be improved upon and equal a superior stock vehicle. Just to make things clear my purpose with modding the RA is not completely about surpassing a stock Evo. The stock Evo is just a bench mark to me. It's mainly about the fun in improving something. If you're faster than me I would not give a ****. I'm not insecure like that.
No, I'm not going to gut the damn car. That would be stupid. Just replace parts that are going to be replaced anyway with something lighter. Lighter wheels, lighter suspension, lighter rotors, lighter seats, lighter clutch, lighter battery and so on and so on. That right there can add up to 100 pounds. Go to the weight reduction threads and you will see how much you can lose by replacing parts with lighter versions.
I did not say that feel has nothing to do with it. Improve your reading comprehension skills, please. I said that I don't care about imitating/matching the feel of the X's handling/S-AWC.
no one gives a sh*t what you want. the FACT is that a used IX would be faster and handle better, dollar for dollar, than a new RA. if you want nav and fast key and all that stuff then fine. but from a pure performance standpoint, the IX is better, FACT!
Of course it's faster when they are both stock. What's your point?
guess you haven't seen this then
That specific TME had more power than the IX. It was not stock. The driver of the IX was also drifting the IX on purpose to make it slow. Sliding slows you down. Did you know that all Evos got heavier and heavier and faster and faster as time went by? The reason why each new and heavier Evo being faster than the previous iteration is because of better technology and more power.
The IX is only faster in a straight line. But the X is faster than the IX on the racetrack where it counts. Dollar for dollar comparison when one car is older and used? Do you want to compare an Evo X to an Evo I also when it comes to performance bargains? With that logic the Evo I wins against the IX.
brembos for almost free?
If I had the money to buy a new Evo It would only be the X MR and I simply can not afford that and it's insurance. It cost 13k more on top of it's most likely higher interest rate. I want it for it's TC-SST and it's faster than both the GSR and RA. In the long run the X MR will cost way more than a carefully and properly modded RA. With 13k worth of aftermarket parts and labor I will not be paying interest.
the reason why they make that car is to sell it to race teams. the RA was meant to be a street car sold to the masses. are you really THAT dumb that you can't figure that out?
I knew that.
I was just showing how stupid your logic was. With everything you said just replace RA with Evo I/II/III/IV/V/VI/VII/VIII/IX and you will realize how flawed it is and you have no respect for any of the older Evos. I do, though.
what does this have to do with anything?
I said that because you implied that a heavier car is inferior. There are other factors that play into a better/faster car. We all know that the X is superior to the IX where it matters, the track. The X MR weighs more than the IX MR by 300 pounds.
comparing old cars to new cars is nothing like comparing 2 new cars where one is intentionally made slower to sell at a lower price point. WTF is your point with every thing you post? it's rubbish. no continuity of argument. no central theme, no nothing. just random retorts with no base in anything relevant. grow up get an education. stop playing gran turismo. read a book put down sport compact car.
I know the RA will be slower. Come on. I already admitted that. Stock for stock mod for mod it will always be slower.
I knew that.
I was just showing how stupid your logic was. With everything you said just replace RA with Evo I/II/III/IV/V/VI/VII/VIII/IX and you will realize how flawed it is and you have no respect for any of the older Evos. I do, though.what does this have to do with anything?
VincentX, i think we don't see eye to eye on one key issue. how much of a value the evo x is.
for all the things the evo gives you over the RA, it comes to way more than $10k if you were to do it by aftermarket tuning. for example, increased track. yes you can buy new fenders, wheels/tires, suspension bits, etc. but how much of that $10k "budget" that you saved by not getting an X, did you use up JUST for increasing the track?
and of course the most important things are the fundamental bits like S-AWC, increased chassis stiffness, quicker steering, etc. yes you CAN do this on a RA just that it'd probably cost more than the car is worth at the end.
so my main point at the end of the day is that if you want a car as fast as an evo... GET AN EVO!!! if you can't afford one then oh well, work with what you can afford.
but the notion that the money saved on buying the RA as a base car to tune is FLAWED because the evo gives you a LOT of extras that you can't cheaply replicate by tuning.
now if this were comparing a $150k euro exotic vs a GTR or something like that for a purpose built track car, THEN i'd say the money saved could be well spent making the cheaper car faster.
IN THIS CASE, the evo is one helluva bargain for what you get if you think about it.
