All Part Number Request Go Here
Old Jul 1, 2008 | 03:14 PM
  #2611
ch47god's Avatar
That's the diagram i was using at the dealership, the item is not listed. The fastener would go horizontally through the bottom of the bumper cover into the back side of the lip. I have a bag of the "62022F" fastener that came in today, but it's not it. Not sure which to try next. Thank you for the help by the way.
Old Jul 1, 2008 | 06:15 PM
  #2612
LakerRaider's Avatar
Originally Posted by Spins4
MB344789
hey thanks alot man, who would have ever known they are called "Clip+scuff Plate".
well you did, how did you?
Old Jul 1, 2008 | 07:59 PM
  #2613
Spins4's Avatar
Hmm..well let me take a look under mine tomorrow and see with an actual visual rather than that horrific pic...
Heh..do a search for my name..lol Well, truthfully it's pretty easy..I have been "playing" with Mitsu's for quite some time (about 9 years)...and oh ya, being a parts manager at a Misu dealership helps
Old Jul 1, 2008 | 08:22 PM
  #2614
dwai's Avatar
I need some help with a part(s), on the front of the block, passenger side, looks like the timing covers bolt to it.
What is that bracket that fills the gap between the timing covers?
Old Jul 2, 2008 | 08:12 AM
  #2615
RussellM's Avatar
Plat Vendor
Link
http://www.mitsubishiparts.net/cart/?id=571&pn=1091A133
Old Jul 2, 2008 | 11:56 AM
  #2616
EvoIXMR's Avatar
Russell -
Need the 2003 Evo VIII RS drive belt (shorter lenght for non-AC)?
Need front 02 sensor as well?
Thanks!
Old Jul 3, 2008 | 10:36 AM
  #2617
RussellM's Avatar
Plat Vendor
Originally Posted by EvoIXMR
Russell -
Thanks!
Here is a link with both parts. The non-AC belt is a non stock part so I would have to order it. If you order it today then I should be able to ship it out to you at the beginning of the week.
http://www.mitsubishiparts.net/cart/...58795+MN191125
Old Jul 7, 2008 | 03:29 PM
  #2618
ch47god's Avatar
Any luck with that part# spins? Russell thanks for the window shades and cargo net i ordered both came quickly. Could you also try and find that part i am looking for? Mount hardware for the lower lip to the front bumper cover. Probably have to order it from you since there is no local dealer, thanks.
Old Jul 8, 2008 | 05:51 AM
  #2619
Spins4's Avatar
Right now, I haven't a clue I tried sticking my head up under mine, and can't really tell. I do have a lip coming in Wednesday for a customer. I am going to take a look at it for S&G's. Because I know the side fasteners are a part of the lip, I learned that when I screwed mine up. If I have no luck checking the lip, I will see if I can get mine on a lift to get a better look.
Might want to check with Russell as well, he may actually have a lip in stock to check.
Old Jul 8, 2008 | 07:15 AM
  #2620
mmartahus's Avatar
Originally Posted by mmartahus
part number for a US version lancer 08-09 DE front grill?
Part number for heated seats switches for canadian version lancer 08-09
Bump this... anyone know the part numbers??
Old Jul 8, 2008 | 09:11 AM
  #2621
RussellM's Avatar
Plat Vendor
You mounting an SE Lip or Standard Lip?
Old Jul 8, 2008 | 09:19 AM
  #2622
RussellM's Avatar
Plat Vendor
Here is a link for the grille. I cant help you with the Canadian Parts, only USDM.
http://www.mitsubishiparts.net/cart/?id=571&pn=7450A095
Old Jul 8, 2008 | 10:06 AM
  #2623
iy's Avatar
iy
How about the vacuum line that runs from the brake booster to the engine (with the check valve in it)?
Old Jul 9, 2008 | 07:23 AM
  #2624
RussellM's Avatar
Plat Vendor
Replied to your PM on this.
Old Jul 9, 2008 | 05:56 PM
  #2625
eclipzed's Avatar
Hello I need a part number. It is the grommet located on the interior passenger side near the center of the console. The one we take out for wideband installs. Here is a pic: Thanks!!
Attached Thumbnails All Part Number Request Go Here-o2_sensor_install_and_routing.jpg
