9653006v5 WORKS for 05 USDM (9694011)
Old Nov 13, 2008 | 08:58 PM
  #181
tephra's Avatar
cool
ill do a Mythbusters:
1% chance it will explode your car
19% chance it will work as planned
75% chance it wont work
Old Nov 14, 2008 | 06:10 AM
  #182
derekste's Avatar
Originally Posted by tephra
cool
and what of the other 5%?
Old Nov 14, 2008 | 12:55 PM
  #183
gear head's Avatar
cool
LOL.....Lets re-phrase that.
100% chance the car will start!!!
Changed the tables as instructed
re-enabled immo........Car starts
Change the immo. to a different code......car does not start.
Took a short drive around the block & the car runs fine.
No CEL at this time.....will take it for a longer drive later on.
Old Nov 14, 2008 | 04:50 PM
  #184
tephra's Avatar
SO IT WORKS???????
cool! will wait for some other tests to dbl check
Also you probably only need to change the very first word, not the whole lot...
Old Nov 14, 2008 | 08:56 PM
  #185
gear head's Avatar
Yep, so far so good.
Old Nov 14, 2008 | 10:49 PM
  #186
KevOVIII's Avatar
Ohhh? So the immobilizer works now? That's the main reason why I haven't switched over to this rom yet.
Old Nov 15, 2008 | 11:28 AM
  #187
logic's Avatar
Confirmed: this change re-enables the immobilizer. Setting an invalid value kills the car, setting it correctly (per my original 96940011 value) allows the car to operate.
Good stuff, tephra!
Old Nov 15, 2008 | 12:42 PM
  #188
gear head's Avatar
Confirmed that only the first word needs changed.
Thanks Tephra
Old Nov 15, 2008 | 11:10 PM
  #189
KevOVIII's Avatar
Wow, nice! Thanks for figuring this out.
Old Nov 16, 2008 | 07:10 PM
  #190
KevOVIII's Avatar
I noticed some differences in ECU_Periphery2 between 06 and 11. In 06, these bits are disabled:
- bit 9 (EGR Test)
- bit 10 (Map)
- bit 13 (Evap)
- bit 14 (Evap)
For the people that need to pass emissions, did you enable those bits? If you did, how did you fix these EGR related tables that are grayed out?
- Boost Enhancment (Anti-lag) Table
- Boost Enhancement Enrich/Enlean (Anti-lag) Map
- Boost Enhancement Adv/Ret Map 1 (Anti-lag)
- Boost Enhancement Adv/Ret Map 2 (Anti-lag)
Last question... I have a JDM Map. Can I leave bit 10 disabled and still be able to log it in EvoScan? I assume so because no one has mentioned it.
Thanks in advance.
Old Nov 16, 2008 | 07:36 PM
  #191
KevOVIII's Avatar
It looks like 06 doesn't support EGR and Evap. Doesn't sound like it would be a problem with emissions either. https://www.evolutionm.net/forums/sh...&postcount=155
Guess I'll flash the car and see what happens.
Old Nov 19, 2008 | 01:47 AM
  #192
jdm4g63tgalant's Avatar
quick question....can i flash an 05 ecu (9694011) with 94170015 w/ tephra mods and run it on a 03-04 VIII?
Old Nov 19, 2008 | 01:57 AM
  #193
tephra's Avatar
why dont you flash 96530006 over the top of 96940011?
Old Nov 19, 2008 | 10:35 AM
  #194
what im really curious about is if there's a benefit to running EITHER rom?
what i'm really doing is swapping a 4g63 into a '87 starion that will run off a evo VIII ecu...im getting a good deal on an ecu that's off a '05.
there seems to be more support on the 94170015 rom which is why i asked if i can/should just flash it over the stock 96940011?
Old Nov 19, 2008 | 02:01 PM
  #195
tephra's Avatar
well if you dont want tephramods then u can leave the rom stock.
