9653006v5 WORKS for 05 USDM (9694011)
Old Nov 11, 2008 | 05:10 PM
  #166
golruss's Avatar
Originally Posted by Charlie_B
Just to make sure...Do this. This is how Ive had mine setup from before I implemented the blobits.
If that doesnt work, turn the valet mode stuff on, and try to deactivate it. Also make sure your init code (cant exactly remember if it causes an issue or not) and immobilizer is copied over. Im not sure if the latter 2 will do anything, but I guess it isnt bad practice.
Thanks alot, will try it tomorrow and let you know.
Old Nov 12, 2008 | 04:09 PM
  #167
golruss's Avatar
Got it started but it shuts off immediately, any suggestions?
Thanks
Old Nov 12, 2008 | 06:22 PM
  #168
fixem2's Avatar
Did you turn off all the Tephra mods? SOunds like the valet mode is on.
Old Nov 12, 2008 | 09:20 PM
  #169
tephra's Avatar
ok - can someone try something for me.
For 96940011 -> 96530006 users ONLY
Add the following definition to your XML (for both 96940011 and 96530006) and then copy the table in 96940011 to 96530006.
Code:
	<table name="ECU Periphery7 Hex" category="Periphery" address="ffa" type="2D" level="2" scaling="Hex16">
		<table name="Y" type="Static Y Axis" elements="8">
			<data>0xffa</data>
			<data>0xffc</data>
			<data>0xffe</data>
			<data>0x1000</data>
			<data>0x1002</data>
			<data>0x1004</data>
			<data>0x1006</data>
			<data>0x1008</data>
		</table>
	</table>
Then re-enable your immobilizer and try and see if the car starts.
If the immobilizer still doesn't work then DONT do anything else just flash back to the old ROM.
If it does work let me know and then just be careful with the car - I don't know what the above definition does yet, All i know is the ROM's immobiliser code are different in this regard.
Old Nov 12, 2008 | 09:24 PM
  #170
scheides's Avatar
EvoM Moderator
Tephra I can test this for ya but it'll be a few days, pulling the head off due to pushing coolant/headgasket leak/failure. Should be back up and running by the end of the weekend.
Old Nov 12, 2008 | 09:52 PM
  #171
tephra's Avatar
coolo.
like I said just be careful with it, I have no idea what that code does.
I just hope it works
Old Nov 13, 2008 | 06:24 AM
  #172
logic's Avatar
If I can get away from meetings today for lunch, I'll give this a try as well.
Old Nov 13, 2008 | 03:23 PM
  #173
golruss's Avatar
I turned all Tephra's mods off, I tried using a clean xml after deleting the old one,
and back to square one will not start anymore. Could some one post up a tried xml please.
Thanks
Ok I set with all mods turned off, I set Valet Rev Limit to 3000, was 114 and it started right up , just need to fix my idle now.
Thanks guys.
Old Nov 13, 2008 | 04:28 PM
  #174
tephra's Avatar
hrmm it should work with it turned off...
Old Nov 13, 2008 | 04:43 PM
  #175
tephra's Avatar
oh are u using V5.10 or V5?
Old Nov 13, 2008 | 04:48 PM
  #176
golruss's Avatar
Tephra I turned them on flashed it then turned it off and flashed it again, it would not start, but when I changed valet rev limit to 3000 with valet mode disable it started right up.???
Old Nov 13, 2008 | 04:49 PM
  #177
golruss's Avatar
I am using V5.10.
Old Nov 13, 2008 | 04:57 PM
  #178
tephra's Avatar
well that bug should have been fixed.
if valet mode is totally disabled then it restores the default revlimitter...
hrmm I will double check it thou!
Old Nov 13, 2008 | 05:09 PM
  #179
golruss's Avatar
Thanks man.
I did send donation.
Old Nov 13, 2008 | 08:44 PM
  #180
gear head's Avatar
Add the following definition to your XML (for both 96940011 and 96530006) and then copy the table in 96940011 to 96530006........
I'll have some time tomarrow afternoon to give this a shot.
