TephraMOD V5.10
Old Aug 19, 2009 | 04:21 PM
  #1141
CGMSTI's Avatar
Installed v5.1 today finally!!
Old Aug 19, 2009 | 04:55 PM
  #1142
nitz's Avatar
thats exactly the problem. It's not normally wired anywhere since the model for that rom had no clutch switch, hence no ecu pinout for it. Am I missing something?
Originally Posted by tephra
Hi Nitz,
Just work out where the clutch switch is NORMALLY wired and use the same pin.
then conduct the "garage test" for nlts to see if it works
Old Aug 19, 2009 | 05:16 PM
  #1143
rolly1818's Avatar
Registered User
tephra, i know this is not the relevant thread, but, do you have Speed Density for 85880014?
THanks!!!
bump for help
Old Aug 19, 2009 | 05:34 PM
  #1144
tephra's Avatar
Nitz - yeah thats what I mean, find the correct pin on another evo 8 that has the clutch switch.. it will be the same pin for your ROMID...
Old Aug 20, 2009 | 06:52 AM
  #1145
nitz's Avatar
tephra..no dice . the only 8 ecu's that have a clutch switch are USDM and the EDM 260. both of which use pin 43 that doesn't work. to make matters worse pin 43 on an 8MR, the original source of the 009 rom, is the crank angle sensor. in addition, i've been in touch with BarryC over on mlr and he's tried several pins for his customers to enable NLTS on the 8MR 009 rom with no success either. any thoughts?
Old Aug 20, 2009 | 07:04 AM
  #1146
tephra's Avatar
are the 4 vs 3 plugs much different in terms of pin out?
like if you flashed a 4 plug ROM (that expects a clutch switch on pin 43) would it work?
Old Aug 20, 2009 | 07:25 AM
  #1147
nitz's Avatar
they are quite different. but remember i'm actually flashing a 3 plug rom, 8MR 009, on to a 4-plug ecu, USDM 8. i originally tried going with a USDM 8 rom but it threw too many codes i couldn't resolve. i'm sure the clutch switch would have worked in that case. *pin 43 is the crank angle sensor on 8MR 009 rom.
8MR 3-plug
8-260 4-plug
Old Aug 20, 2009 | 07:34 AM
  #1148
the_mork's Avatar
Have you tried 9653 or 9005? These are the roms that commonly have no problems moving across applications. At least for DSMs we had big problems with all of the USDM roms. 9653 worked well for us but threw a few minor codes that needed to be taken care of with periphery bits.
Old Aug 20, 2009 | 08:02 AM
  #1149
tephra's Avatar
ok so what ECU do you now? and what ROMID do you have now?
Old Aug 20, 2009 | 09:11 AM
  #1150
nitz's Avatar
right now i have a usdm 8 ecu with 96260009 rom id.
Old Aug 20, 2009 | 09:27 AM
  #1151
nitz's Avatar
just to confirm are you listing the first 4 or last 4 digits of the rom id's i should try, and are they tephra patched.
Old Aug 20, 2009 | 09:31 AM
  #1152
nitz's Avatar
tephra,
the following was suggested..
Originally Posted by AndyF_RSX
Probably the easiest way to find out which pin works is to get the actual memory address from Tephra that he uses for the NLTS code. You can then change one of the MUT table entries to log that particular memory location he uses in evoscan.
Then it's a case of starting the car, leave evoscan running whilst logging the chosen location and ground out each spare pin in turn to see which one alters the logged value.
Old Aug 20, 2009 | 10:42 AM
  #1153
Appauldd's Avatar
NLTS and all other Tephra "stuff" works great on my 94170015. I have not tried the conversion like others though.
I am about ready to make the switch. Just have to port over all my "tuned" tables.
Old Aug 20, 2009 | 01:42 PM
  #1154
the_mork's Avatar
First four, and yes there is a v5.10 rom for each. There is also a v7t6 rom for 9653.
96530006
90550001
Old Aug 20, 2009 | 02:13 PM
  #1155
kaj's Avatar
kaj
Quick question:
Garage test for NLTS? How do I this??
Very intimidating to think about testing while going ***** out down the street. Lol
