How remove bumper and install HID bulbs!
Old Mar 1, 2004 | 09:53 PM
kdogg's Avatar
You'll need to remove the fog and high beam bulb (turn counter clockwise). Unplug the headlight harness (below and between the fog and high bulbs). You'll need to grasp the release buttons which are on top and bottom of the harness. *NOTE: Be careful not to touch the bulbs!!!
Old Mar 1, 2004 | 09:54 PM
kdogg's Avatar
Now looking at the back of the headlight assembly, unscrew the only screw and turn cover counter clockwise.
Old Mar 1, 2004 | 09:55 PM
kdogg's Avatar
Turn plug CC
kdogg's Avatar
Push retaining ping down and out. After it releases, you can swing it open. You can just pull the bulb out. *NOTE: DON'T TOUCH THE BULB!!!
Old Mar 1, 2004 | 09:56 PM
kdogg's Avatar
Compare old with the new in box. Make sure you don't accidently use this 'old' bulb for the passenger headlamp.
Old Mar 1, 2004 | 09:57 PM
mifesto's Avatar
wow nice
Old Mar 1, 2004 | 09:58 PM
kdogg's Avatar
Reverse the install for the headlamp assembly, and install back on the car.
*NOTE: When installing the headlight assembly on the car, make sure the gasket near the amber turn signals are on the outside of the fender.
Turn on the car and test all three bulbs.
Old Mar 1, 2004 | 10:00 PM
kdogg's Avatar
For the passenger side headlight assembly....
You need to remove the resevoir tank and its 2 bolts first. Then you can tackle the 1 clip and 4 bolts on the headlight. For some odd reason, the wires and harnesses are a little tighter on this side, so be patient.
Attached Thumbnails How remove bumper and install HID bulbs!-step907-custom-.jpg
Old Mar 1, 2004 | 10:01 PM
kdogg's Avatar
Follow the bulb replacement instructions above, reinstall headlight assembly with note on headlamp gasket. Turn on car and test all three bulbs.
Bam, the new bulbs are in... Now reverse bumper removal instructions.
Hopefully your EVO looks like this...
Old Mar 1, 2004 | 10:06 PM
kdogg's Avatar
It's really hard to take pictures of light. So my pics don't really do justice. This is the best one though - drivers side has upgraded bulb while passenger side still has stock bulb. The new bulbs are rated 5800K. Stock are rated at 4300K.
4300K - yellow/white output
5100K - white/blue output
5800K - blue/purple output
Anything adverstised higher than 6000K isn't worth installing. Bulbs with that high of Kelvin rating actually emit a lower brightness light.
I got my bulbs from European AutoSport http://www.europeanautosport.com/evo.htm
Hope this helps
Attached Thumbnails How remove bumper and install HID bulbs!-compare-small-.jpg
Old Jun 2, 2004 | 06:48 AM
M3lachsilber's Avatar
choad
Discuss thread here.
Old Jun 2, 2004 | 08:28 AM
LancerEvoMR's Avatar
Blain, don't forget to close.
Closed.
tlcoll1
Feb 24, 2018 10:06 AM
DontStopMe
Jun 23, 2015 09:43 AM
kdogg
63
Jan 5, 2015 08:38 PM
JPooah
Sep 29, 2008 07:10 PM
cbrkp
Canadian Forum
12
Aug 28, 2008 05:17 AM
