how do you remove the philips head clip
so i'm taking off my front bumper, but can't figure out how to get the clips with the philips head screw in the center. if i turn it, the screw just spins in place.
is there a trick? i checked the manual and it just says turn counter clockwise, i've tried both under the car, in the wheel wells and the screw will always just spin
answers? seems pretty easy but it's my first time taking off the bumper.
Some will suck and you will have to cut them... I think they are like $1.50/ea from the dealer
If you just touch the side if it with your hand that is not screwing, and don't push at all on them while you are trying to unscrew (don't strip them!) they should come out pretty easily. A small cats claw/prybar might help also.
The reason they don't go anywhere when you push on them is because they are made to screw out, but simply push back in (speeds things up at the factory).
ok i just completed taking off my front bumper.
tips:
1. just rip the stupid philips clips out. i got fed up with them, and just used a flathead to pry them up, then needle nosed and yanked the whole thing out. took like 15 mins after that. and they are still intact.
2. i got stuck taking off the intercooler mesh. had to reach under with a 10mm socket and get the 6 or so bolts off.
tips:
Thats what I did, and I highly recommend only installing half of them as needed, as it will make your next removal all that much easier.
sleet
145
Feb 20, 2014 01:28 PM
iodine23
47
Jun 11, 2010 07:10 AM
iodine23
Apr 12, 2004 09:24 PM
