My FP Black
Old Aug 7, 2010 | 05:43 PM
  #196
binky's Avatar
Originally Posted by RockmanX
no lift shifting i hope you have a built tranny if you dont you will have one soon
HA....nope I don't at the moment.
-Bink
Old Aug 7, 2010 | 05:48 PM
  #197
binky's Avatar
Alright guys....
So the past 2 days the evo has started to smoke...pretty bad actually. It started at idle and then would go away. Then only happened in between shifts. Now it smokes up to 2000 RPM's.
I'm guessing it could be one of the following:
1) Turbo seals
2) Something wrong with the head / valves etc
3) The ring(s) could be fried
I did a compression test before the turbo install and it was 175 175 175 175.
I haven't done one after the install. I will in the next few days or have my mechanic do one.
FWIW my oil return line had been leaking and I just re-installed a new gasket and RTV'ed the hell out of it.
It's weird...I just took it for for a ride and it didn't smoke at all....I don't get it?
What should I be looking for / checking?
Thanks!
-Bink
Old Aug 7, 2010 | 06:59 PM
  #198
ToxicFab's Avatar
Dang bink! Didn't know you had a black! Just got mine. Good luck with everything bro.
Old Aug 7, 2010 | 07:44 PM
  #199
RockmanX's Avatar
hmmmmmmmmmmm time to take it to a evo shop and get it inspected bro do it right and dont play guessing games with a expensive car with expensive mods LOL
Old Aug 9, 2010 | 06:10 AM
  #200
binky's Avatar
Thanks man!
-Bink
Old Aug 9, 2010 | 06:16 AM
  #201
binky's Avatar
Well....
Here's what I think happened.
I re-installed the gasket between the oil return line and the oil pan and had used a bunch of RTV (definitely more than I should have). I used a 1G gasket because the Evo gasket I used was leaking like crazy and I've used the 1G gaskets in the past with no issues.
According to FP's FAQ - 'My tubo is smoking and it's brand new. The shaft has normal play in it so is one of my seals blown?' http://store.forcedperformance.net/m...creen=Info_FAQ
It basically says that if there is the slighest restriction in the return line, it can cause it to back up to the bearing housing, it will leak past the seals and into the exhaust where it burns it.
Which would explain why the longer I drive the worse it gets. If I let the car sit for a while, the return line drains and it will take some time for it to fill back up, which is why it doesn't smoke for a while after starting it.
Soo, tonight, I am going to pull off the gasket NOT RTV it like I did last time, and just RTV the bolts and around the return line flange, check the shaft play and call it a day. Hopefully it fixes it....
-Bink
Old Aug 9, 2010 | 06:50 AM
  #202
ToxicFab's Avatar
Originally Posted by binky
Thanks man!
-Bink
not a problem, have you decided on a stock replacment manifold yet? i can wait to see what kinda power one makes with a black or if it helps with spool up.
Old Aug 13, 2010 | 05:09 PM
  #203
binky's Avatar
Thumbs down
Well...Bad news
Apparently my #2 cylinder has had enough!
It had been smoking pretty bad lately. I did a compression test today and here are the results:
Cly #1: 175 | Cly #2: 152 | Cly #3: 175 | Cly #4: 175
I re-did the test a few times on cylinder 2 to see if it changed and it didn't. I added oil to the cylinder and re-did the test and the compression went up. Guess its the piston / ring....time for a built motor...
Need to start making an excel spread sheet to go over my engine options.
-Bink
Old Aug 13, 2010 | 05:39 PM
  #204
wizzo 8's Avatar
Damn how many miles?
Old Aug 13, 2010 | 06:00 PM
  #205
RockmanX's Avatar
well good news is that there are a couple built motors for sale so you dont have to build one from ground up if you dont want to average price 3000k i think its time to join my exculsive club binky fp black 2.4 club
Old Aug 13, 2010 | 06:23 PM
  #206
wizzo 8's Avatar
I noticed that also rock but like you said i would rather build than buy
Old Aug 13, 2010 | 07:32 PM
  #207
binky's Avatar
52,200 I believe.
Rock - 2.4 is definitely on the table
It's just kinda weird, because before the turbo upgrade it was 175 across the board. The car lasted ~roughly 3 weeks with the Black on it.
I mean as bummed as I am...I'm happy it didn't actually blow up and put a rod threw anything. It's a really good excuse to build the motor
-Bink
Old Aug 13, 2010 | 07:41 PM
  #208
RockmanX's Avatar
Its only a good excuse if your ready for it and you have the funds for it to be honest with you LOL.
Old Aug 13, 2010 | 07:48 PM
  #209
binky's Avatar
Isn't that the truth....I wasn't planning on building the motor for at least a year. I'm going to start saving up! Back on the Ramen noodle diet
We'll see what happens
-Bink
Old Aug 16, 2010 | 08:09 AM
  #210
binky's Avatar
Well as of right now, my course of action is going to be the following:
1) Drive the car and pull the exhaust manifold off and see if I can tell where the oil is coming from
2) Do a leak down test
Depending on what those say - I am going to build the motor.
Right now I am looking at staying at a 2.0 L. I think I am going to have AMS build it.
I am also considering an AMS head and F1 intake manifold. I am going to install everything myself (with the help of some of friends hopefully ) then do the engine break in and possibly have them tune it. I'm not sure what I want to fully do yet. By the time I save the money for it it won't be for 3 maybe 4 months anyway.
I am going to go through my options to see if I want AMS / MAP / Buschur to build it. OR maybe I will build it - have to learn sometime right?
What do you think?
-Bink
