Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
Old Feb 13, 2011 | 08:37 PM
  #136
tephra's Avatar
mmm ok...
well hopefully its ok..
good luck!
Old Feb 14, 2011 | 12:52 AM
  #137
merlin.oz's Avatar
I feel your pain Jon, it sure does sound like a serious bust-up.
Old Feb 15, 2011 | 09:50 AM
  #138
Jumperalex's Avatar
Best answer to the file count problem is the same as what most camera's do. They either create a new folder for every day, or a new folder for every power cycle. It also helps immenesly with organization.
Old Feb 22, 2011 | 10:15 PM
  #139
fostytou's Avatar
EvoM Community Team
FYI I started adding a page to the Wiki. Feel free to add to it:
http://evoecu.logic.net/wiki/Standalone_Logging
Old Mar 2, 2011 | 06:47 PM
  #140
KyleH's Avatar
Can someone help me out with the proper script to trigger logging only when the car is running? I've tried multiple attempts including cut and paste from what others have done, as well as trying to create my own formula and have failed miserably. Thanks!
Old Mar 2, 2011 | 09:15 PM
  #141
Golden's Avatar
Doesn't it automatically log when the car is on? Do you have the car on for long periods without it running?
Old Mar 2, 2011 | 09:20 PM
  #142
tephra's Avatar
yeh...
u get a new log when you start the engine...
Old Mar 3, 2011 | 05:05 AM
  #143
KyleH's Avatar
Yes. And, yes. However, unless I was reading incorrectly, I thought there was a way to make it log only when the car was running. Having a bunch of files on there when the engine isn't running isn't something I really want, if for nothing else, just to avoid all the hassle of mining through all the useless files.
With that being said, if it's not something that has been figured out at this point, I'm certainly okay with the current setup. In fact, many thanks to those who figured this out. It will save me from having to figure out a way to strap in a laptop on the track.
Old Mar 3, 2011 | 06:59 AM
  #144
Golden's Avatar
Oh, it could easily be done. Use a trigger of RPM > 0. But... Why the hell are you turning your car on and off without starting it? Isn't the point of a car to turn it on, drive it somewhere and shut it off?
Old Mar 3, 2011 | 10:09 AM
  #145
fostytou's Avatar
EvoM Community Team
Take a look at the wiki link I posted or the config file I posted. Just make sure your RPM pointer in the logstart / logstop commands is the same as the logged item above it (and as noted, I recommend adding speed too).
Old Mar 3, 2011 | 10:56 AM
  #146
KyleH's Avatar
So my concern is the split second I go beyond the "on" location to start... I want to avoid it creating a log of this split second before I start the engine.
Old Mar 3, 2011 | 04:26 PM
  #147
KyleH's Avatar
Okay... not sure why, but I got it working. I think I overcomplicated it earlier. Anyway, for those that are code-challenged like myself, it was a simple copy and paste from Fosty, and then substitute my nomenclature ("RPM") for what he had.
Now it only logs when engine is running. Yay. Here's what the code looks like, should this be able to help anyone in the future:
;-------------triggers---------------
; note that parameters must be previously defined
; before defining triggers using them
; triggers allow you to control when logging starts and stops
; this example sets up triggers such that logging only occurs
; when the engine is running (RPM > 0)
; triggers consist of some evaluation of the form [trigparam] [condition] [value]
; and a resulting action which is done if the evaluation is true
;paramname=CruiseLight
;paramid= 0x8045C5
;databits=1
;offsetbits=5
;isvisible=0
;priority=2
;conditionrpn = CruiseLight,1,==
;action = start
;conditionrpn = CruiseLight,0,==
;action = stop
; only log when the engine is running
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
Old May 3, 2011 | 01:39 PM
  #148
verkion's Avatar
Standalone Logging - conditionrpn statement...
Anyone know if the conditionrpn can only do multiple/chained comparisons? I want to have it start a new file whenever I go WOT and come out of WOT but only if I have logging activated. Trying to do this:
If CruiseLight==1 && TPS>92 && #TPS<=92
"start a new file"
If CruiseLight == 1 && TPS <92 && #TPS >=92
"start a new file"
So I thought that would look like this:
conditiorpn = CruiseLight,1,==,TPS,92,>,&&,#TPS,92,<=,&&
action = newfile
conditiorpn = CruiseLight,1,==,TPS,92,<,&&,#TPS,92,>=,&&
action = newfile
But it doesn't seem to work. Any ideas?
Thanks!
verkion
Old May 4, 2011 | 08:41 AM
  #149
fostytou's Avatar
EvoM Community Team
https://www.evolutionm.net/forums/8914442-post120.html
;conditionrpn = CruiseLight,1,==,2ByteRPM,1500,>,&&
;action = start
;conditionrpn = CruiseLight,0,==,2ByteRPM,1500,<,||
;action = stop
; start logging to a new file when the throttle goes from previously below 80 to above 80
; #throttle refers to the previous throttle sample
;conditionrpn = TPS,80,>,#TPS,80,<=,&&
;action = newfile
You might try excluding the cruiselight condition if you are already logging, or use a start stop command instead of the newfile command if you only want to log when WOT (and exclude your third condition with the previous value variable). I'd also recommend lowering the TPS threshold since you want to make sure it is logging during spool and your max TPS might only be 93.
Old May 4, 2011 | 10:41 AM
  #150
verkion's Avatar
Thanks for moving the thread!
That's a good point regarding the Cruiselight condition. It should only generate/increment the file number when it is ALREADY logging right? i.e. the action = newfile won't do anything anyways when its not logging.
Thanks!
verkion
