What is the max load are u seeing guys?
Old May 7, 2011 | 10:35 PM
  #286
evo_gerard's Avatar
IPW limit removal for 90550001 please!!!!!!!!!!!!!!!!!
Old May 7, 2011 | 10:48 PM
  #287
tscompusa2's Avatar
next time search better..
22030 for fuel limit
22014 for load limit
<table name="Set to 9 to remove load limit" address="22014" type="1D" level="1" scaling="Hex16"/>
set both to 0x0009
Old May 8, 2011 | 10:15 AM
  #288
evo_gerard's Avatar
set both to 0x0009
lol sorry! but thanks again!
gerard
Old May 28, 2011 | 11:39 AM
  #289
tscompusa2's Avatar
fp black in full combat mode 42psi taper to 35.. not recommended for the average user with this turbo. but this illustrates some major load/airflow/boost from this little guy that is a stock frame turbo.
was done 2 days ago. Log ends at 6800rpm.
Old Aug 6, 2011 | 06:43 AM
  #290
Mellon Racing's Avatar
[QUOTE=jcsbanks;6530449]96260009:
<table name="Set to 9 to remove load limit" address="25d40" type="1D" level="1" scaling="Hex16"/>
does anyone have the code to remove the fuel limit on 96260009 too? I have a 3794R car that's going to go way over 380 soon.
Old Mar 3, 2012 | 05:45 PM
  #291
[QUOTE=Mellon Racing;9514204]
Originally Posted by jcsbanks
96260009:
I have another car with the same problem, anyone found the fix for this?
Old Mar 3, 2012 | 07:57 PM
  #292
tscompusa's Avatar
this is everything in my notes folder
96940011: <table name="Set to 9 to remove load limit" address="28140" type="1D" level="1" scaling="Hex16"/>
94170008/94170015: <table name="Set to 9 to remove load limit" address="26592" type="1D" level="1" scaling="Hex16"/> <table name="Set to 9 to remove fuel limit" address="265AE" type="1D" level="1" scaling="Hex16"/>
96260009: <table name="Set to 9 to remove load limit" address="25d40" type="1D" level="1" scaling="Hex16"/>
90550001: <table name="Set to 9 to remove load limit" address="22014" type="1D" level="1" scaling="Hex16"/>
96530006: <table name="Set to 9 to remove load limit" address="27824" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 9 to remove IPW limit" address="27926" type="1D" level="1" scaling="Hex16"/>
88840017: <table name="Set to 9 to remove load limit" address="2901a" type="1D" level="1" scaling="Hex16"/>
85590015:
<table name="Set to 9 to remove load limit" address="2a49c" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 9 to remove IPW limit" address="2a69a" type="1D" level="1" scaling="Hex16"/>
see what other rom 96260009 inherits and most likely will be the same IPW limit removal
Old Mar 3, 2012 | 11:19 PM
  #293
donner's Avatar
Try this for 9626:
<table name="Set to 9 to remove IPW limit" address="25F00" type="1D" level="1" scaling="Hex16"/>
Old Mar 4, 2012 | 12:27 PM
  #294
todd6027's Avatar
@ donner any chance of same for 88570008 please
Old Mar 5, 2012 | 01:51 AM
  #295
todd6027's Avatar
sorted
Old Mar 5, 2012 | 08:15 AM
  #296
Originally Posted by donner
Try this for 9626:
that looked correct in the ROM so I set to 9 but didn't see a change in the AFR. It's possible that we aren't far enough above 380 to make a difference yet. Thanks for sharing that.
Old May 24, 2012 | 02:19 AM
  #297
merlin.oz's Avatar
Looking for the two limit address's for 88580014, if some kind person has them.
Old May 24, 2012 | 08:27 AM
  #298
sorry don't have that one either
Old Dec 14, 2014 | 02:10 AM
  #299
merlin.oz's Avatar
Looking for confirmation of the load cap and fuel cap address for 88570008 please.
I have 2C9FC and 2CA0A but nothing to confirm they are correct.
The correct address were sent to my by Donner and are:
263F4 Load
266D6 IPW
Old Dec 24, 2014 | 03:13 AM
  #300
burnzy's Avatar
those addresses don't seem to work on 88580714?
