What is the max load are u seeing guys?
Old Jan 2, 2009 | 11:06 AM
  #91
psphinx81's Avatar
get to work good sir!!
Old Jan 3, 2009 | 07:40 AM
  #92
jcsbanks's Avatar
The load limit calculation is correct, but in working through it, it gets clipped to a byte at a crucial point which stops our table changes having any effect. I think I'll nobble it somewhere else instead
Old Jan 3, 2009 | 08:23 AM
  #93
jcsbanks's Avatar
Mellon, for 96940011, try adding this to your xml and change the value from "2ba1" to "0x9".
<table name="Set to 9 to remove load limit" address="28140" type="1D" level="1" scaling="Hex16"/>
I hope this allows higher than 380 load, pls check for normal behaviour, and that it registers the correct fuelling and timing from your maps though as there could be other limits or overflows in there.
I would just put the earlier tables I mentioned back to stock, no longer necessary, this disables their effect anyway.
Old Jan 3, 2009 | 08:29 AM
  #94
Ted B's Avatar
Quick Question:
I also have an EVO 8 and am in the same place as Mellon. However, I have 94710015. I have not yet tested the 380 load limit since setting the earlier tables to "255". Shall I do that first, or should I just await Mellon's result and inquire about this same fix for that ROM?
Old Jan 3, 2009 | 09:43 AM
  #95
jcsbanks's Avatar
I don't think it will work with the tables, let's wait and see if the fix for Mellon works, if so I can move it to the other ROMs on request.
Old Jan 3, 2009 | 09:47 AM
  #96
Ted B's Avatar
Sounds good. I'll stand by.
Old Jan 3, 2009 | 10:50 AM
  #97
Mellon Racing's Avatar
thanks John, I rolled back the previous settings and implemented this new one. I'm going out to run a few errands and will report back with results shortly.
Old Jan 3, 2009 | 11:43 AM
  #98
success! idle/cruise/wot looks normal and feels fine to me. Thanks Jcsbanks!
Code:
4531.25	149.375
4593.75	158.75
4625	168.75
4718.75	180.625
4750	195.625
4843.75	217.1875
4906.25	239.375
5000	272.8125
5093.75	305.3125
5187.5	343.75
5343.75	344.375
5500	341.25
5625	356.875
5750	365
5906.25	370.625
6062.5	373.75
6218.75	381.5625
6375	383.4375
6531.25	386.25
6656.25	389.0625
6843.75	389.375
6937.5	392.5
7062.5	392.5
7218.75	391.25
7343.75	385.625
7437.5	383.75
7593.75	381.25
7750	377.5
7843.75	373.4375
7968.75	370
Old Jan 3, 2009 | 12:26 PM
  #99
jcsbanks's Avatar
Excellent, glad it works.
Ted, 94170008/94170015:
<table name="Set to 9 to remove load limit" address="26592" type="1D" level="1" scaling="Hex16"/>
Old Jan 3, 2009 | 12:28 PM
  #100
Vigman's Avatar
Hi,
Can someone give me any opinion on my post #73 please?
Thanx.
Old Jan 3, 2009 | 12:43 PM
  #101
l2r99gst's Avatar
Originally Posted by Vigman
Hi,
Thanx.
That load seems too high for 22 psi at your elevation. Doing some quick math, it seems pretty far off, assuming intake temps of 120F.
Old Jan 3, 2009 | 12:49 PM
  #102
grayw's Avatar
Do you have the location for 90550001 and 96260009 please?
Old Jan 3, 2009 | 01:02 PM
  #103
cossie1's Avatar
  #104
jcsbanks's Avatar
96260009:
<table name="Set to 9 to remove load limit" address="25d40" type="1D" level="1" scaling="Hex16"/>
90550001:
<table name="Set to 9 to remove load limit" address="22014" type="1D" level="1" scaling="Hex16"/>
Old Jan 3, 2009 | 01:03 PM
  #105
jcsbanks's Avatar
Pls check these are all 2ba1 before you change to 9.
