What is the max load are u seeing guys?
Old Apr 15, 2009 | 03:48 AM
  #151
Mellon Racing's Avatar
Originally Posted by Creamo3
Just checking in to see if you received your fuel rail and were able to test
I just got word that my fuel rail is on the way finally ...still gotta freshen up this clutch though.
Old Apr 15, 2009 | 12:30 PM
  #152
project_skyline's Avatar
Originally Posted by jcsbanks
1 byte load is still good, just change the scaling from 1.2 to something bigger.
In evoscan im assuming?
Old Apr 15, 2009 | 12:37 PM
  #153
jcsbanks's Avatar
In Evoscan and the ECU. Tephra shows the multiplier in his xml mods IIRC.
Old Apr 15, 2009 | 03:26 PM
  #154
mac214's Avatar
You need to change it in ecuflash and in evoscan. I changed mine to 1.3 and am good to 320ish (not sure on the exact number).
Old Apr 16, 2009 | 11:38 AM
  #155
Does anyone know what its shown as in ecuflash, i found it in evoscan but not ecuflash.
Old Apr 20, 2009 | 12:04 AM
  #156
ramievo7's Avatar
Iam seeing 330ish 2 byte on 21 psi evo 9 turbo no boost leaks & on sea level is it normal ????????????????!!!!!!!
Old Apr 20, 2009 | 06:30 AM
  #157
Creamo3's Avatar
Definitely not normal, have you rescaled your MAF for aftermarket intake?
Old Apr 20, 2009 | 09:37 PM
  #158
raasfaas's Avatar
Just want to confirm something here...is it normal to be seeing higher loads and slightly leaner AFR after installing an intercooler? Nothing else was changed, just swapped out the stock unit for an ETS and I'm now hitting about 10% higher loads (340ish to 350ish), and like .4 of a point leaner.
Old Apr 22, 2009 | 03:20 AM
  #159
ramievo7's Avatar
Creamo3 scaled but i did't touch the value's in its lol what i have to do here!!?
Old Apr 22, 2009 | 09:05 AM
  #160
rolly1818's Avatar
Registered User
could be a boost leak (yeah i know...for some reason no one likes to admit to it lol)
280 load to 220 (1 byte) 24/25 psi to 20.
Old Apr 23, 2009 | 07:26 PM
  #161
raasfaas's Avatar
just looking for confirmation to post #158
Also, is 340ish load (2 byte) normal for a stock IX turbo running 29psi on meth with the mods in my sig??
Old May 2, 2009 | 08:26 PM
  #162
lan_evo_mr9's Avatar
Max on E85=335. Max on pump with lower boost (3psi)=285. Quite the difference I think, but expected. I did a comparison for the first time tonight, only reason being is that every E station is currently out of E. Had no choice but to fill with the "normal" gas. First time I actually used the map switch to do it's job. Worked perfect. Thanks Tephra and J of T. I will say that 50-60 hp/tq difference is very noticeable. It sucks. LOL.
Old May 3, 2009 | 05:31 PM
  #163
David Buschur's Avatar
2 byte load on Project White right now is 403.
Old May 3, 2009 | 05:40 PM
  #164
kanyonkid's Avatar
i hit 290 with full bolt ons, stock turbo, roughly 24psi
Old May 4, 2009 | 12:15 AM
  #165
nonschlont's Avatar
right now Im seeing 295-305 1 Byte load @ 24.6 - 25psi
