What is the max load are u seeing guys?
I see the most of 260. There must be something wrong. I have a gt35r,cams,cam gears,big front mount, full 3in exhaust, stock injectors and running 22psi, 255 fuel pump, all hard pipe all.the bolt ons, stock head and block and tuned. I think my biggest down fall is stock injectors. What do you guys think.
you're only at 22psi and not making much power if you're on stock injectors, that's why you're seeing 260 most likely.
btw, I found a log where I did a pull at 40psi on Q16
Code:
RPM LoadMUT2Byte 4102 142 4156 146 4191 152 4238 159 4309 168 4375 179 4422 190 4512 203 4617 222 4645 251 4773 276 4883 309 4914 347 5098 390 5293 421 5371 431 5520 431 5727 437 5918 450 6109 457 6309 450 6473 444 6648 437 6801 430 6965 421 7145 413 7340 406 7492 398 7598 391 7723 386 7910 380 8031 373 8160 367
Code:
Anybody have a clue were it is? I want to get off pump and turn up the wick. Since Im knocking on 380 loads door right now on pump.
What loads do you think I should hit with 1000cc injectors with my mods? This is to mellon.Im on 91 pump my afr is 11.2 timing is at 4deg at top with no knock at 85 degrees outside and intake temp is at 110 deg. Thanks MELLON for the info.
Might be a good time to say goodbye to that ROM. I just converted from that ROM to the EDM 96530006 ROM without any big problems.
