What is the max load are u seeing guys?
FWIW, the MAF will see the greatest test of its capacity at peak hp, whereas peak load will reflect peak torque. As for how 470 load translates to real torque in the application in question, I have no idea. I do know that it means a few more load cells in the fuel and ignition tables would be nice ...
that pretty high for only 23psi but then again it's a 2.3 so maybe that's normal. I would do a boost leak test and make sure you aren't sucking in more air through the maf than you think (boost gauge)
ya its true Mellon i had boost leak and fix it now i see no more than 350 on the same boost but i have one Q what i have to do to get more than 300 load in the maps without having problems i'm running 90550001 ??!!!!! like 30 psi boost looooooool
you can change the values and tune for it
The most I am seeing is about 320 in 3rd running 30-31psi on 100% meth...I wonder if I am running too much timing or what? I am running 5* to 7* at peak load with about 13* up top. It falls to the 290 load at 7000. I will have to try it out will less timing once the snow clears. There seems to be no knock but I am road tuning.
226 is my highest logged - Load 1 Byte on V7. This was done on a 5,800 RPM two step launch that built 8.5psi.
Outside temp was aprox. 55°F w/90% humidity.
First gear load then hit the 226 at 3,687 RPM, 18 psi, -1 timing, 944 airflow per my log.
Mods in sig.
I rarely go over 200 1 byte load when WOT and no launch.
Mods in sig.
