What is the max load are u seeing guys?
Old Aug 6, 2009 | 08:55 AM
  #226
AWD_Terror's Avatar
ive peaked at like 320-330 or so on my setup in the last week or two while tuning.
Using the MUT2Byte also.
Old Aug 8, 2009 | 11:32 AM
  #227
whitey4d's Avatar
96420008 address help PLEASE!!! Im geting very desperate!
Old Aug 8, 2009 | 12:04 PM
  #228
FJF's Avatar
FJF
299 2-byte load @ ~24PSI. Stock everything except a Buschur FMIC, TBE w/HFC, MBC, and a drop-in filter.
Old Aug 8, 2009 | 12:17 PM
  #229
vmrevo9's Avatar
Veteran: Air Force
i see around 305 calculated (not 2byte) with ~24psi stock IX turbo
Old Aug 8, 2009 | 04:26 PM
  #230
rolly1818's Avatar
Registered User
^^^ boost leak? Intake?
Old Aug 8, 2009 | 04:28 PM
  #231
EVOIXreno's Avatar
330 2 byte 303 load calc on meth at 5000ft elevation.
when im at sea level it's 305 on both 2byte and load calc
Old Aug 8, 2009 | 05:31 PM
  #232
bambooi's Avatar
355 I think.
Ok I went and looked. 355.6
Old Aug 10, 2009 | 08:27 AM
  #233
Mellon Racing's Avatar
I just checked mine on pump gas 93 octane 32.5psi in this crazy 90+ degree heat with 70% humidity...seeing 404 load peak
Old Aug 10, 2009 | 09:07 AM
  #234
wip's Avatar
wip
Pfffff, boost leak
P.S. Bet that's fun...
Old Aug 18, 2009 | 12:45 PM
  #235
doing a lil e85 testing at 40psi, 470 2byte load
Old Aug 18, 2009 | 01:18 PM
  #236
MR Turco's Avatar
you are nuts chris. That poor stock maf
Old Aug 18, 2009 | 01:21 PM
  #237
Ted B's Avatar
FWIW, the MAF will see the greatest test of its capacity at peak hp, whereas peak load will reflect peak torque. As for how 470 load translates to real torque in the application in question, I have no idea. I do know that it means a few more load cells in the fuel and ignition tables would be nice ...
Old Aug 18, 2009 | 01:25 PM
  #238
linuxman51's Avatar
after applying the load cap fix and re-scaling, i'm seeing around 391 right around 28ish psi. Car feels pretty nasty, I can't imagine what mellon's setup feels like.
Old Aug 18, 2009 | 05:16 PM
  #239
SWOLN's Avatar
Just retuned today. 304 load at 26 psi.
Old Aug 18, 2009 | 07:18 PM
  #240
EVO8LTW's Avatar
Originally Posted by EVO8LTW
Fwiw, I see 300 load with a Red and 24 psi. Stock MAF pipe and 1050cc injectors scaled at 975.
I was just looking at some old logs when I had an FP white rabbit turbo, but otherwise a similar set-up. I hit 260 load at 25 psi vs. 300 at 24 psi with the FP Red.
