What is the max load are u seeing guys?
Old May 9, 2009 | 06:18 AM
  #196
Mellon Racing's Avatar
WB02 kits are cheap...
Old May 9, 2009 | 07:03 AM
  #197
Jack_of_Trades's Avatar
He's waiting for his Innovate to come back from repair.....once again.
Old May 9, 2009 | 11:38 AM
  #198
nitz's Avatar
Dave I'm assuming you're probably running some large injectors being on e85 and was wondering how you got away with such a low scaling, 665. Is this because you did your MAF scaling prior injector scaling. The order of this is confusing me since they'll both have an effect on your fuel trims which is used to determine how well 'scaled' you are. I'm on some RC1000 and have them at 812cc so far.
Originally Posted by davidbuschur
Thank you for the input on this guys, greatly appreciated.
Now that my MAF size is set back to stock 357.7, the max load I am seeing is about 415, that is at peak torque (which I'd expect). That is at 500 whp/49X ft lbs on our dyno. Injector size is set to 665.
Old May 10, 2009 | 10:17 PM
  #199
fostytou's Avatar
EvoM Community Team
He is on E85. That requires ~30+% more fuel (or smaller scaling) than pump.
Old May 11, 2009 | 08:34 AM
  #200
David Buschur's Avatar
Yes, I am running E85 and I can't answer the injector scaling. I know the fuel trims are on the money and that is where they ended up.
Old May 11, 2009 | 09:59 AM
  #201
MR Turco's Avatar
Originally Posted by Evo8Emperor
Im seeing usually loads of about 290 at 24 psi with a ported evo 9 turbo. Even with the new meth kit and the boost up to about 26-27 psi and no other tuning done yet its still in the 290's.
probably not making power anymore. Logs would help though. peak and load curve might tell different stories.
Old May 11, 2009 | 05:46 PM
  #202
Evo8Emperor's Avatar
Its gone up since then Ive been seeing up over 305 to 310 so far with about 18 degrees of timing up top. I tried increasing it more but I was getting knock. I think I need to put a hault on advancing timing until I check my AFR im sure there very rich and that whats making the car knock.
Old May 11, 2009 | 06:52 PM
  #203
Most meth'd evo8's run between 18-21* up top from the maps I have saved. Most ran between 3-5* at peak load too when between 27-29 psi. Just my observation.
Old May 11, 2009 | 07:20 PM
  #204
Appauldd's Avatar
It is amazing how much more timing you can run with Meth. I am only at about 15* up top and like 2* at peak load. I am, however, running 27-28 PSI and finally doing so with no knock. I had to remove a ton of timing in the mid range 100-200 load. My car sure does not like a lot of timing.
Old May 11, 2009 | 07:38 PM
  #205
It's amazing what cooler air intake temps and increased octane can do LOL. Knock resistance is about the same as 100 octane race fuel but with less combustable energy so timing is similar but power levels are a little lower.
Old May 11, 2009 | 08:42 PM
  #206
JohnBradley's Avatar
I am only seeing 235 at 29psi on a 3586 and I am making 504whp
MAFT Pro is a beautiful thing
Old Jul 5, 2009 | 02:57 AM
  #207
jcsbanks's Avatar
85590015:
table name="Set to 9 to remove load limit" address="2a49c" type="1D" level="1" scaling="Hex16"/>
table name="Set to 9 to remove IPW limit" address="2a69a" type="1D" level="1" scaling="Hex16"/>
Old Jul 5, 2009 | 06:12 AM
  #208
MR Turco's Avatar
JCBanks - i see original value of 0x2AB1, change that to 0x0009?
Old Jul 5, 2009 | 07:04 AM
  #209
mrfred's Avatar
Originally Posted by jcsbanks
85590015:
Just want to mention that changing these values is *not* compatible with jcsbanks' speed density patch. His SD patch by design removes load clipping.
Old Jul 5, 2009 | 09:54 AM
  #210
whitey4d's Avatar
Can Anyone post the address for the 96420008 ROM please! Im in the 360s right now and still on pump. I want to start a race gas tune here soon. Thanks !!
