AEM EMS Get tuning help for your AEM EMS system.
Help car wont start
Old Aug 27, 2005 | 10:13 AM
R3dline's Avatar
Help car wont start
As you all might know, Im runing the wr, well my problem is that when I got my car back from the shop, it took like 8-10 secs to start the car. Is that normal? Now my car wont start at all! I tried turning it on for like an hour, gave up tried it next morning and still no luck. I have the wr, aem ems, cam gears, hks shafts, dp, tbe, 255 fuel pump, mbc, perin fuel rail, 780 injectors, xs ignition amp, aem intake, jdm mr bov. Does this have to do anything with the ems? Thanks for the help. By the way, after getting the car back (tuned@ harmanmotive) pulled really hard!!
Old Aug 27, 2005 | 11:47 AM
R3dline's Avatar
bump
Old Aug 27, 2005 | 11:50 AM
Widebandphillip's Avatar
post cal file
Old Aug 27, 2005 | 04:31 PM
R3dline's Avatar
Sorry but I dont have my cal file with me. I also smell fuel, to me everything seems to work, it just wont start. Where can I find the cam sensor? TY!!!
Old Aug 27, 2005 | 05:19 PM
i don't think you'll have to sync timing if you don't have cam gears. If you smell fuel, take out like 80 percent on the crank raw fuel on the startup table. Just use the wizard to set the aem up for all the evo sensors.
Old Aug 27, 2005 | 05:32 PM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
check your ignition set up.
Old Aug 27, 2005 | 05:34 PM
Precision Dyno's Avatar
AEM EMS takes a while to sync for the evo.
You can fix part of it but it will be hard if you do not know how to navigate thru the software.
I can try to get it step by step for you on the phone if you like. But you have to have access to a laptop and communication cable for the ems.
Old Aug 30, 2005 | 12:21 PM
ninjadoc's Avatar
Also make sure your battery is fully charged. If its down some the car won't start...I think it won't stat synch with a low battery.
Old Aug 30, 2005 | 06:49 PM
R3dline's Avatar
Well harmin motive took charge and within 2 mins found out the problem, it was the ignition fuse! Now my car is running how it should, like a monster powered by a lil White Rabbit
Old Sep 15, 2005 | 03:32 PM
FullBlown's Avatar
Thats good to hear. How did the fuse snap??
memphis raynes
AEM EMS
10
Jan 19, 2014 09:34 AM
Criddlen
18
May 1, 2009 02:14 AM
crisdiarata
AEM EMS
Jan 18, 2009 08:54 PM
Mike.p
AEM EMS
Oct 31, 2007 06:49 PM
