Blown motor--opinions?
Originally Posted by alpha
It doesnt look like it wasnt tuned properly. Hence the flat map. I dont tune DSM's so I cant comment on the excessive ignition timing. 13 degrees from 5,000RPM to 7,700RPM and 9lbs to 21lbs? Also, the vacuum portions of the map are very similar to AEM's startup MAP calibration. Do you have a dyno sheet you can post from the day of the tune? Not pointing fingers. Just point a couple things I noticed out.
Originally Posted by VTECH8TR
I hope your joking right. This map is VERY bad, and if oyu don't see that you haven't tuned an AEM.
<Edit>
I probably should have worded my post differently.
</Edit>
I agree. Where did I say it was good
Do you have a dyno sheet you can post from the day of the tune? Not pointing fingers. Just point a couple things I noticed out.[/QUOTE]
His dyno is here.http://www.cardomain.com/ride/783461
If A/F isnt "good" and timing is "good" the motor (ringlands, pistons, etc) can go. If A/F is "good" and timing isnt "good" the motor (ringlands, pistons, etc) can go. They both need to be "good"
I sent an e-mail to Sergio at CFT asking him or Rolo to explain why it is that they, and nobody else, believes this was a good tune.
In the mean time, I thank everybody for taking the time to help me. I am very impressed with the support people are offering.
What I really need now is a recommendation for somebody in central Florida who can tune this thing correctly. Vijay in Tampa comes pretty well recommended. Anybody have any other suggestions?
* Enthalpy in Tampa
* Jason Koehler in Pensacola
* Darin (Titan Motorsports) in Orlando
* Mase in Jacksonville or Gainesville
Brad Brooks also comes down every couple months todo some tuning. I know he is coming back down soon to tune a couple DSM's and Honda's. And st00pid over in Texas might be coming here soon.
We come down there frequently.
There is only one person to tune your car. YOURSELF. Educate yourself and take small steps and teach yourself. Seriously, tuning isnt rocket science. You will learn what is a safe max timing on different grades of fuel and at different RPM ranges, max safe boost levels on different grades of fuel in relation to timing and AFR's. Then once you gather all this information. Learn your software and start making small changes with the goal of meeting those safe levels. NOBODY will spend the right amount of time on your car except you. (unless you can afford to pay them). I can nail a UTEC fuel map with incredable accuracy in about an hour. Ramping from 14.7 following the load of the engine to 11.4 afr on 100 octane. A year ago, i didnt even know what OBDII was. Education is POWER!!!!!
I attached pictures for the people who can't see.
Bad situation.
