AEM EMS Get tuning help for your AEM EMS system.
Can AEM be used as a fan controller?
Old Dec 5, 2005 | 08:21 PM
bolsen's Avatar
I'm looking to get the Flex-a-lite FLX-112. Will I need to get the termostat control or can I use the ems to configure the fan to come on at a certain temperature?
http://store.summitracing.com/partde...2&view=1&N=115
Old Dec 5, 2005 | 08:30 PM
Soon2Bgreat's Avatar
It's my understanding the AEM has plenty of inputs that can control that. Might want to run it by AEM to be sure though as i've never personally used one
Louis
Old Dec 6, 2005 | 07:19 AM
kcevo's Avatar
Yes you can control the fan with the AEM. Are you planning to just remove your factory fan for the slim line unit in the pic?
Old Dec 6, 2005 | 07:26 AM
VTECH8TR's Avatar
Yes it can, KCEVO is knowledegeable to tell ya , moving to the aem forum.
Old Dec 6, 2005 | 11:27 AM
bolsen's Avatar
Thanks for the info guys
Old Dec 6, 2005 | 09:41 PM
silverofs's Avatar
i have looked everywhere for a toggle fan spot or smething like it & have not seen anything.. are you sure you can control the fans directly by turning them on or off??? if so let me know i only have one fan on my car.
Old Dec 7, 2005 | 08:02 AM
kcevo's Avatar
You can control the fan with a low side output and a relay. IF you removed the stock fan and still have the fan control module, then hook the (+) and (-) from the two wire plug on the module to the (+) and (-) on the slim line unit.
Old Dec 7, 2005 | 04:51 PM
silverofs's Avatar
yeah i know you can do it that way but the one in front of the radiator can you turn it on & off when & how you want??? i know how to hook a fan up the main one is not there i have my controller still hooked up to the other one just can't find anything in the aem programs to toggle the fan!!!!
Old Dec 8, 2005 | 06:00 AM
kcevo's Avatar
The radiator fan is triggered by LS #2. When looking at the configure outputs box LS#2 is not viewable so you will have to view the options for it in the full list drop down box. Also, note that the startup map and most maps I have seen have LS #9 configured as the radiator fan output when looking at the Configure Outputs box, but per the wiring diagram than is for the front o2 heater.
Old Dec 10, 2005 | 10:13 PM
silverofs's Avatar
cool thanks man i will check into it & see what i can find..
Old Dec 11, 2005 | 12:46 PM
GTVEVO's Avatar
Does anyone know what the vendors sell their slim fan kits for? And do they supply the hardward to bolt it up correctly? I am in need of a slim fan.
Old Dec 11, 2005 | 07:48 PM
kcevo's Avatar
Tommy, I can supply you with a fal or something else with the mounting hardware just let me know what size you are looking for.
Old Dec 12, 2005 | 08:28 AM
GTVEVO's Avatar
Which size or part number do most vendors use? I had bought one before but there was no way it would fit, mount up correctly and actually save space.
Old Dec 12, 2005 | 08:44 AM
kcevo's Avatar
I would guess somewhere around the 10 - 14 inch is what they use, I'll have to measure the one I got with the AMS turbo kit. The flex-a-lite that is mentioned above by bolsen is what most use, and the mounting hardware comes with it. The hardware mounts it so it is thru the core of the radiator, they also have another mounting kit you can buy to mount another way like stock.
MitsuJoe
E85 / Ethanol
47
Dec 14, 2015 06:10 PM
golgo13
Jan 26, 2014 04:19 PM
flx919
Jul 11, 2011 06:22 PM
Nesiop
Automotosports - Illinois
Jun 9, 2011 02:14 PM
crypto
Lancer Engine Tech
32
Jul 19, 2006 12:29 AM
