AEM EMS Get tuning help for your AEM EMS system.
o2 question
Old Dec 26, 2005 | 03:59 PM
Kerr's Avatar
Fomer Vendor
o2 question
Ok, I ordered an EMS and the wideband o2 and have a question with the o2s. The best place to put the wideband woud be in the location of the pre-cat o2, correct? So the plan is to put the wideband in place of the stocker, or does the EMS use the stock o2's. Also, a lot of people are using test pipes, does that effect anything?
When looking through this AEM forum, there were things about using the MAF or converting to map, am I right on that, whats the differences between using them.
Thanks for the help.
Matt
Old Dec 29, 2005 | 02:48 AM
bryans2k's Avatar
I would actually just put it after the cat in the second location. The stock location of the first o2 seems a bit too close for it to last long there. Test pipes don't affect anything other than the ozone and your ears.
I personally would convert to map as it makes more sense when your tuning and the stock maf is a bit quirky.
bryan
Old Dec 29, 2005 | 03:26 AM
Jakeg97's Avatar
best place for the wideband o2 sensor location is before the cat, and at least 18inches away from the turbo
Old Dec 30, 2005 | 07:36 AM
Kerr's Avatar
Fomer Vendor
So would it be bad to put it in the outlet housing? Should it be further down in the down pipe?
Old Dec 30, 2005 | 09:02 AM
bryans2k's Avatar
yes
Old Dec 30, 2005 | 12:37 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=84914
Old Dec 31, 2005 | 08:23 AM
twinscrewed's Avatar
Originally Posted by burningmoney97
Thats exactly how I installed mine. I used that thread as a guide. Welded the bung just before the test pipe. I'm using a UEGO though, not an LM-1(not that it makes a difference). The hole in the passenger side footwell made it VERY easy. After I had the bung welded on to the downpipe, it only took me about 30 minutes to reinstall the DP, run and splice the wires, and mount the gauge.
Old Jan 1, 2006 | 06:56 PM
DynoFlash's Avatar
Has anyone else noticed how long these AEM 02 sesnors last? I am amazed at the life span I have had on my race car - and this is even using race fuel with lead - great job aem
Jonas
Lancer Engine Management / Tuning Forums
12
Apr 15, 2009 04:17 PM
LakerRaider
Jan 17, 2009 11:18 AM
jeemybo
17
Aug 24, 2006 08:21 AM
03redtype-s
Mar 2, 2006 09:10 AM
BRKENG
Aug 8, 2004 05:32 PM
