AEM EMS Get tuning help for your AEM EMS system.
EVO will not start! please help
Old Mar 12, 2006 | 11:43 PM
IEXCELR8's Avatar
Could be the coils. Also could be the cam sensor as mentioned it may be 180 degrees off.
Load your buddy's map in it and put it in his car and see if it works in his. That way you can eliminate the aem.
Old Mar 13, 2006 | 03:16 AM
LIFER's Avatar
good point thanx.
Old Mar 13, 2006 | 10:10 AM
kcevo's Avatar
If you don't get stat sync then you won't get the coils to fire nor the injectors to fire, it's that simple. With no stat sync then the cam or crank sensor are the issue. First I would check all the fuses, then check the power and ground to the cam and crank sensors, if this checks out check the signal coming from the cam and crank sensor while cranking the car.
If this all checks out I would see if a local could swap AEM boxes with you or put your box in their car with their .cal file like mentioned above and go from there.
Old Mar 27, 2006 | 01:15 PM
Torre from Va.'s Avatar
Chad C. is the man.
Old Mar 27, 2006 | 01:32 PM
kcevo's Avatar
Originally Posted by Torre from Va.
Chad C. is the man.
Thanks man. BTW, did you get your no start issue taken care of?
Old Mar 27, 2006 | 01:37 PM
of course not !
Old Mar 27, 2006 | 01:40 PM
kcevo's Avatar
of course not !
Are you getting Stat Sync?
Old Mar 27, 2006 | 01:42 PM
no........... I haven't done what you said yet........ I think the crank sensor is 180 out
Old Mar 27, 2006 | 01:47 PM
kcevo's Avatar
That sucks, I know you'll get it figured out. If you need anything else don't hesitate to get in touch with me.
Old Mar 27, 2006 | 01:48 PM
Absolutely............. I haven't hesitated yet bro, thanks again !
Old Apr 4, 2006 | 12:03 PM
peru evo's Avatar
One thing is you can change the cam rising edge and the cam following edge, this may help. from on to off and/or vice versa
keep us posted
Old Apr 4, 2006 | 12:05 PM
peru evo's Avatar
sorry is the "falling edge"
audiofan
Oct 9, 2016 04:34 PM
ryanholder24
Aug 29, 2016 07:08 PM
Paulevo9
Aug 15, 2015 09:02 AM
GearJamminMR
Oct 21, 2014 04:17 PM
Llew
Sep 6, 2013 01:09 PM
