AEM EMS Get tuning help for your AEM EMS system.
I need a base map for cams
Old Mar 23, 2006 | 08:49 PM
dryad001's Avatar
Just what the title says, I need it for 264/264cams, stock injectors. If anyone could help me out I will be most grateful. Right now the car is running on the start-up map.
TIA
Old Mar 23, 2006 | 11:30 PM
kf6ytc's Avatar
If you are asking this quesion....... Sell your ECU and go back to stock, get a reflash or piggyback...... You will be 100% ahead...... because if your asking for a 'cam basemap' you obviously have no clue what your doing, and you going to blow your engine like everyother person of your caliber that purchases the ems......... Might sound like dick advice, but it will probably save your motor..... The ems is NOT intended for inexperienced people. I've don't HOURS of reading, and taken efi101 (www.efi101.com) and i am still not competitent to be tuning my own ecu.
beware.
Old Mar 25, 2006 | 10:58 AM
dryad001's Avatar
beware.
it's not for me. Just trying to help someone out to just get the car started. Seriously I could care less what classes you have taken and what you think I asked for some help and I get a "you dont know anything" post.
Myself personally I dont see the need for the EMS the stock ecu is great, remember these cars have only been here 3 years, the top tuners are still finding the loopholes in the stock ecu to make it run even better and create more HP.
Old Mar 25, 2006 | 10:02 PM
kf6ytc's Avatar
Your comments clearly show your lack of knowledge into the EMS system, My comment may have been 'rude' by truthfully it will save your friends motor..... If your asking for a 'cam basemap' it is very clear you are CLUELESS and have a good chance at doing damage to the car using an ems system. I dont clearly understand where you are going with your 'stock ecu' comment, but again, it shows your lack of knowledge on this subject......
Define a 'top' tuner......... AMS? BUSCHUR? DYNOFLASH? guess what? They all use the AEM EMS for their cars.............. What does that tell you about their 'reflash' product.......
Old Mar 26, 2006 | 08:48 AM
dryad001's Avatar
I can admit it, I dont know a lot about the system. Would he drive around on it for days? No. It's simply to get about 3 miles to the dyno where a aem authorized tuner can take over. Go give your advice somewhere else, it's not wanted here.
Old Mar 26, 2006 | 08:49 AM
Precision Dyno's Avatar
TIA
PM me I will send you something today
Old Feb 21, 2007 | 01:12 PM
sabastian458's Avatar
Precision could you give me something similar or possibly the same just for 720 cc injectors?
Old Feb 22, 2007 | 02:38 PM
bump. . .
Old Feb 22, 2007 | 09:01 PM
Aby@MIL.SPEC's Avatar
TIA
what other mods do you have?
i have a 264 cal file, 3" tbe, 255 fp, oem injectors running speed density.
pm me a email address & I will send it to you.
i hate when peole have negative stuff to say.
There is a a-hole on the aem forums who talks with the same all-mighty / Iknow it - knowledge & since you dont know as much as he does, you should sell your car, ecu & ride a bike, because your not worthy...yet if you look @ his first post's, he was asking similar how-to questions......
good luck
Old Feb 23, 2007 | 06:14 AM
good luck
I really hope that all of that was not directed to me. Unforutantly your map wont work, I have 720's, 255lp, 264 cams and gears, and I'm VTA. I do not know a lot about the AEM system, I will admit it. That is why I am asking for a base map.
Old Feb 23, 2007 | 06:41 AM
EVO8_PR's Avatar
Not to be disrespectful but you should not use anyone's map for anything else than to look it over and compare their setting to yours. If you do not have the knowledge to tune the car yourself don't fool around uploading calibrations. Do you have a wideband installed and hooked up to log with the AEM? If so pm me your .cal file and log of a full throttle run, and I could try to help you out.
Old Feb 23, 2007 | 06:45 AM
Yes There is a wideband installed with the AEM. scorke has my file saved on his laptop. I will try to get him to post it on here.
fuzzychi
Jul 24, 2010 06:13 PM
fuzzychi
Jul 9, 2005 01:21 AM
AdamsssEvo
11
Mar 10, 2005 09:17 AM
eclipse176
18
Aug 20, 2004 01:49 PM
